Latest post Mon, Oct 15 2018 6:16 AM by gjango. 11 replies.
Page 1 of 1 (12 items)
  • Fri, Oct 5 2018 12:45 PM
    • gjango
    • Joined on Fri, Sep 28 2018
    • Posts 16
    • Points 200
    Import Audio into one Track
    Hi guys.
     I would like to import my clips while the sound is not split on two mono tracks in the timeline
     but in an audio track I then import "center". how does it work?
  • Sat, Oct 6 2018 7:34 PM In reply to
    • Tom Pearson
    • Joined on Thu, Mar 1 2007
    • Los Angeles CA / Minneapolis MN
    • Posts 2,161
    • Points 23,185
    Re: Import Audio into one Track
    just highlight the track you want on the timeline and load away
    Mac Pro 3.5 gig 6 core 64 gig ram D700 radons with ssd os drive with a 20 tb raid, Artist Mix and Artist color Artist control [view my complete system specs]
    Tom Pearson
  • Tue, Oct 9 2018 4:20 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,518
    • Points 64,035
      Moderator: MCA Mac
    Not exactly sure what you're asking but here are 2 things to try:
    1. In the Audio Project setting you can set the default pan settings for dual mono tracks as either L/R and Center.
    2. If you want to import a track as Stereo, click on the MultiChannel Audio button on the Audio Tab in the Import Settings.
  • Wed, Oct 10 2018 12:52 AM In reply to
    • Tom Pearson
    • Posts 2,161
    • Points 23,185
    If you are looking for a 50 50 mix of l/r on one mono track like in sound forge you cant. But you could do a center pan mono mix down of the l/r tracks
    Tom Pearson
  • Wed, Oct 10 2018 12:51 PM In reply to
    • gjango
    • Posts 16
    • Points 200
  • Wed, Oct 10 2018 12:52 PM In reply to
    • gjango
    • Posts 16
    • Points 200
    Why is this not posible?
  • Wed, Oct 10 2018 11:10 PM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,518
    • Points 64,035
      Moderator: MCA Mac
    As a rule you can't convert sources on import.  You can take multiple audio tracks and group them into Stereo or Mulit-Channel audio but you can't combine multiple tracks into fewer tracks.  The principal here is to bring in sources unmodified and then do any conversions within the timeline where the work can be both apparent and modifiable.  If you did this combining of the audio tracks from dual mono to single mono there would have to be some way to make it repeatable if it had to be done again...but there isn't.  Modifying the tracks before importing also makes the process repeatable because you're importing the modified media rather than the originals.
    But if you've got 2 mono tracks that are the same, bringing in only 1 track, center panning it and boosting it +3 db gets the same result.
    Hope that helps.
  • Sat, Oct 13 2018 10:08 AM In reply to
    • gjango
    • Posts 16
    • Points 200
    Thank you for your help. I do not understand how I get it in just a mono track. Of course, I could only activate a track in the player but there is no setting that he just inserts a mono track?
  • Sun, Oct 14 2018 6:53 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,518
    • Points 64,035
      Moderator: MCA Mac
    If it’s a single mono track, no problem. If you need to do some conversion to make it a single mono track first, you’ll need to do that before bringing it into Media Composer.
  • Sun, Oct 14 2018 7:16 AM In reply to
    • gjango
    • Posts 16
    • Points 200
    I'm sorry for the silly questions but how do I get a simple mono track? I always have two mono tracks for l / r. Unfortunately, I have very little idea of ​​audio and Premiere / final cut was synonymous never a problem.
    my client has a master sequence and that only contains single mono tracks. how does it work? Thanks for your help.
  • Sun, Oct 14 2018 2:14 PM In reply to
    • MikeyB
    • Edlesborough, UK
    • Posts 475
    • Points 5,890
    Are you saying you want to have dual-mono - ie 2 mono sources 'voices' on one track in the timeline? If so, why? Surely it's better for each mono source to occupy its own track so that it's independently manipulable.
    But if you really want to do it...
    A 2-track mono clip can be converted into a Stereo clip by using the Clip/Modify/Modify Clip/Set Multichannel Audio command. This will combine the 2 channels into one stereo, panning them l and r.
    You can then re-centre them, by using the Clip/Audio/Centr Pan command. This will give you 2 mono channels in one 'Stereo' track....
    MacBook Pro 15" 2016 2.7GHz i7 Radeon 455 [view my complete system specs]
  • Mon, Oct 15 2018 6:16 AM In reply to
    • gjango
    • Posts 16
    • Points 200
    I will try this. Tank you.
