Latest post Fri, Oct 19 2018 11:02 PM by dasari. 2 replies.
  • Sat, Oct 13 2018 8:25 PM
    • dasari
    • Joined on Sat, Oct 13 2018
    • Posts 2
    • Points 20
    What is the best export setting in Avid Media Composer for uploading the video on YouTube ?
    Hi Avid Experts,
    I have I have a film that is 12GB in size. the video quality looks great when I play it on my system. But when I upload it on YouTube, the quality does not look good even though it is playing with 1080p HD quality.
    I am trying to figure out if I have to select any particular setting for YouTube uploads.
    The settings I have used are below:
    Compression Type: Avid DNxHD Codec
    Resolutions: 1080p/23.976
    Aspect ratio: Native (1920X1080)
    I do not want to compromise on the video quality and I need assitance with the best encoding possible.
  • Tue, Oct 16 2018 3:47 PM In reply to
    Re: What is the best export setting in Avid Media Composer for uploading the video on YouTube ?
    I always encode (with Squeeze) to MP4 when creating a file for uploading to YouTube.  YouTube seems to play nicer with MP4's than with other formats.   If you have Squeeze, there is a YouTube/Vimeo pre-set you can use.
    MC 2018.4 with Symphony, Matrox MX02 Mini Max, Win 7 Pro, HP Z800 2x6-Core 3.2Ghz Xeon, 48GB ram, Quadro K4200, SanDisk Extreme 240GB SSD as system drive... [view my complete system specs]
  • Fri, Oct 19 2018 11:02 PM In reply to
    • dasari
    • Posts 2
    • Points 20
    Hi Terry Snyder
    Thank you for the response. I do not see the squeeze option that you have mentioned. I will try and see if I can use MP4 format and I hope it does not spoil the quality of the video.
