Latest post Wed, Oct 17 2018 8:57 PM by Lukas Boeck. 9 replies.
Page 1 of 1 (10 items)
  • Tue, Oct 16 2018 5:41 AM
    • wkumingo
    • Chicago
    • Posts 172
    • Points 2,380
    AVCHD waveforms
    Does anyone have an efficient workaround to see the audio waveforms while working with linked AVCHD footage? All the posts around here regarding this subject are from 2013.
    Self-built -- Always current MC version with AJA KONA 1 card OS: Windows 10 Pro 64-bit, System: X99 Motherboard, Core i7-6850K, GTX 1080 Ti, 32GB RAM... [view my complete system specs]
  • Tue, Oct 16 2018 11:48 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,627
    • Points 60,455
    Re: AVCHD waveforms
    Transcode to a proxy format during editing and then link back to your originals prior to final export. That's one solution.
    Camera(s) PXW-X70, HDR-FX1, Hero 6 Black | MC 18.12.1 | QT 7.7.9 | Continuum 2019 | Sapphire 2019 | Mocha Pro 2019 | Titler Pro 6 | Windows 10 Pro x64... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Tue, Oct 16 2018 4:08 PM In reply to
    • wkumingo
    • Chicago
    • Posts 172
    • Points 2,380
    Re: AVCHD waveforms
    Unfortunately transcoding isn't preferred, due to having hours of footage and a deadline. I hadn't thought of making proxies and relinking, maybe I’ll do that next time. More importantly, I can't believe this issue hasn't ever been fixed.
  • Tue, Oct 16 2018 4:53 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,627
    • Points 60,455
    Re: AVCHD waveforms
    When I asked about this a couple of years ago, I was told (by Avid) that there is a technical reason why they don't show waveforms for AVCHD material but I have trouble believing that it is something other than a performance penalty that a more powerful system couldn't overcome.
    Steve
  • Tue, Oct 16 2018 10:15 PM In reply to
    Re: AVCHD waveforms
    Give it a try! Console command wfTglAvchd (at least that was it a couple of years ago...)
    I haven't tried it in a while, but last time I did, I found myself quickly turning it off.
  • Wed, Oct 17 2018 12:24 AM In reply to
    • wkumingo
    • Chicago
    • Posts 172
    • Points 2,380
    Re: AVCHD waveforms
    usatraveler:
    I haven't seen Avid crash so hard in quite some time, hah! Sadly all I got was the spinning blue wheel and unfortunately no waveforms. I didn't know about this Console command though, thanks for the suggestion.
  • Wed, Oct 17 2018 2:57 AM In reply to
    • touviere7
    • Joined on Mon, Mar 15 2010
    • los angeles
    • Posts 596
    • Points 6,750
    Re: AVCHD waveforms
    when i come acrross some avchd files from an old gh2 hacked to high bitrates, i quicky rewrap the files to .mov files, making sure to select audio .wav 48k/16 or 24bit. it takes no time and does not affect the video at all.
    very happy with hdcinematics V6
    import file(s) - batch is possible - convert media format - video codec -wrap to mov. - audio codec48k_16
    the app let you do a zillion other things as well...and it's free, or just a small donation.
    symphony 2018.12.5 - win 10 pro64 v.1803 - QT essential 7.7.9 - nVidia gtx1080 OC (430.64) - intel i7 6800k@4.1ghz water cooled by corsair H100i V2 - MSI... [view my complete system specs]
  • Wed, Oct 17 2018 3:46 AM In reply to
    • wkumingo
    • Chicago
    • Posts 172
    • Points 2,380
    Re: AVCHD waveforms
    touviere7:
    hdcinematics V6
    It seems this app is behind a PayPal pay wall. Even though it's very cheap I'm hesitant to pay for a utility to do something that Avid should've addressed by now. Rewrapping sounds like the best way to go all things considered, but I'd be chewing up twice as much drive space for both versions of the media, and the file extension change would probably make relinking between the two difficult (I've already started working on the project).
    I guess I'll put this feature on the wait list. (Right next to that new Title Tool!)
  • Wed, Oct 17 2018 2:05 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,572
    • Points 45,855
    Re: AVCHD waveforms
    V6 is now just a front end for FFMPEG (which is free). It makes it much easier to build the FFMPEG comand line, and can batch convert files. You can do it all in FFMPEG and loop through a list of files using Windows command mode, but this makes it simpler. Note that you must also download FFMPEG separately along with V6. If you learn the commands for FFMPEG you can do it all for free.
    Dave S.
  • Wed, Oct 17 2018 8:57 PM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 481
    • Points 5,755
    Re: AVCHD waveforms
    I was in that situation a while back.
    I put video and audio on a timeline and did an audio mixdown, removed AVCHD audio.
    edited from that.
    If things go wrong, you can machframe back to the avchd audio.
    MC 2018.12.2 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-6, Mojo DX, Artist Color, Flanders CM240, GTX... [view my complete system specs]
