Latest post Fri, Oct 26 2018 5:31 AM by hbrock. 3 replies.
  • Mon, Oct 22 2018 3:06 PM
    • mt55
    • Joined on Mon, Oct 22 2018
    • Posts 2
    • Points 30
    Jump to Audio TC in Sequence Not Working
    Hi, I'm trying to jump to an audio TC (A1, for example) in a sequence using the numeric pad, but it doesn't seem to work.
    I have the A1 TC selected in the top display of the Tracking Information menu. I'm on a 2013 Mac operting 10.13.3 (High Sierra) and my Avid version is 2018.5.0.
    Side note: Video TC work. I'm able to jump to a V1 or a V2 TC without problem.
  • Wed, Oct 24 2018 9:20 PM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,518
    • Points 64,035
      Moderator: MCA Mac
    Re: Jump to Audio TC in Sequence Not Working
    Have you enabled 2 Data Displays on the top of the Composer window?  If so, can you try assigning both to Source A1 and see if it works?
  • Wed, Oct 24 2018 9:28 PM In reply to
    • mt55
    • Posts 2
    • Points 30
    Thanks for the response, hbrock! Unfortunately, I have tried that and still nothing...
  • Fri, Oct 26 2018 5:31 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,518
    • Points 64,035
      Moderator: MCA Mac
    Silly question: you’re not trying to enter a non-drop frame number when you have a drop frame source or entering non-existent frame numbers?
    Here’s another thing to try: duplicate the sequence, delete the video tracks and see if the search works. (Just trying to figure out where the problem is coming from.)
