Latest post Mon, May 13 2019 6:05 AM by Jeroen van Eekeres. 5 replies.
Page 1 of 1 (6 items)
  • Wed, Oct 31 2018 8:02 PM
    • farhadd
    • Joined on Tue, Apr 27 2010
    • Posts 44
    • Points 595
    Dynamic Relink Settings broken 2018.10
    2018.9 and 2018.10 both exhibit this bug (I haven't checked anything prior to 2018.9). When I open the Dynamic Relink Settings Window and try to check the "Enable Dynamic Relink" checkbox I'll see the detailed settings appear briefly and then the box unchecks itself and the settings hide themselves again. Please look into this.
    Mac Pro Late 2013, Mac OS 10.13.6, MC 2018.12.3, 6 core 3.5GHz, dual D500 3GB VRAM, 256GB SSD, NEXIS 5500 over 1GbE [view my complete system specs]
  • Thu, Nov 8 2018 3:46 PM In reply to
    • farhadd
    • Posts 44
    • Points 595
    Re: Dynamic Relink Settings broken 2018.10
    Bump
  • Mon, Nov 12 2018 2:00 PM In reply to
    • jakeheat
    • Joined on Sun, Sep 3 2006
    • Posts 491
    • Points 5,905
    Yes, I can confirm this is broken on my machine too.
    Media Composer 2018.9 MacPro 6 core - 32 GB RAM - OS:10.13.6 3.33Ghz iMacs, Macbook Pros. BM, AJA, Matrox After Effects, etc [view my complete system specs]
    @jaketheeditor
  • Mon, Nov 12 2018 2:46 PM In reply to
    • Posts 10,279
    • Points 219,095
    Farhadd
    Can you please add system Specs to your profile.  I can create a case and get this into the pipeline but I will need your specifications like comouter, RAM< graphics card, processsor, OS, etc etc.
    Click on your name in the right hand corner of the screen.  Then select edit profile on the left nav bar and enter your spec's.  makes it very easy to help you then.....
    standing by for you to add then and will then create a case for you and Jakeheat!
  • Mon, Nov 12 2018 2:57 PM In reply to
    • farhadd
    • Posts 44
    • Points 595
    done, thanks
    Marianna:
    Farhadd
  • Mon, May 13 2019 6:05 AM In reply to
    Hmm, have you ever found what was causing that?
    I still see this with 2018.12.3 on a non supported testing system. On a Win10 HP z4 the settings window functions normally.. now the relinking itself but I have another thread open for that.
    Is it maybe because you need MC ultimate edition?
    Avid reseller ACSR at Telmaco
    http://www.telmaco.gr/en/
