Latest post Thu, Nov 29 2018 2:08 PM by wjasonspencer. 11 replies.
Page 1 of 1 (12 items)
  • Wed, Oct 31 2018 9:14 PM
    VDM3BobVideoOut error with MC 2018.10 and 2018.8
    Hey everyone,
    Anybody run across this error recently?  VDM3BobVideoOut::Setup:Unexpected state
    Shows up in the source window as I'm logging clips, usually when shuttling video.  Effectively freezes MC and sometimes causes it to crash.  It's annoying as all get-out, and the only way to avoid the error is to restart avid with my Blackmagic Device disabled.  Of course, that makes it sort of hard to work with any efficiency...  Seems to run normally without my BM hardware connected.
    I've experienced this running MC2018.10 and 2018.8, but not prior to those versions.  I ran 2018.3 for months without this issue.  I have reason to believe that this has something to do with my Blackmagic Mini Monitor and newer versions of MC, but as far as I know I'm running the Avid recommended BM drivers (most current 10.11.4, and previously I ran 2018.8 with BM 10.11.2 and experienced the same problem).  Now running on a clean install of Windows 10 Pro with dual GTX1070 cards and a newer GeForce driver.
    Got any ideas what this could be caused by?
    EDIT:
    I got one more error just now, one I hadn't seen yet:
    "Exception: Fatal Open I/O Error - Callback consistency check failure"
    Just wanted to add that.
    Avid Media Composer 2018.10 MSI GT73VR 6RE Titan SLI Intel i7 Laptop Windows 10 Pro 64GB RAM USB3 media storage BlackMagic Design UltraStudio Mini... [view my complete system specs]
    Jason Spencer, Director/DP/Editor digitallunchbox.com
  • Wed, Oct 31 2018 9:32 PM In reply to
    Re: VDM3BobVideoOut error with MC 2018.10 and 2018.8
  • Fri, Nov 2 2018 1:09 AM In reply to
    Anybody out there???Smile
  • Fri, Nov 2 2018 10:08 PM In reply to
    • Sergi Lladó
    • Joined on Fri, Jun 11 2010
    • Vic, CATALONIA
    • Posts 18
    • Points 230
    Been having this problem since I don't remember when. This is a very serious issue that makes my monitoring useless and it's getting worse in every update. I cannot work properly.
    I have a decklink mini monitor in one machine and a decklink 3D extreme in another and both are having the same errors. Can someone from Avid give us a solution? I'm paying for something that should work and it's not.
    I'm open to tests if somone at avid is interested in solving this.
    By the way, I'm using the same cards in Davinci Resolve with no issue.
    Please, give us a solution!
    Intel i7-4930K 3.4Ghz, 64GB RAM, Nvidia Quadro K2200, Win 10 Pro x64, MC2018.9, DeckLink Mini monitor HD. [view my complete system specs]
  • Sat, Nov 3 2018 4:55 PM In reply to
    I will gladly second this.  I installed older BlackMagic Desktop Video version 10.10 in hopes that it was just BM drivers.  I'll report if that makes a difference or not after I've had a chance to work with my system today.
    In other news, the audio trim issue is driving me batty!  Freezes every time I attempt to trim using caps lock on. https://community.avid.com/forums/p/185929/864924.aspx#864924
  • Mon, Nov 5 2018 1:55 PM In reply to
    • Sergi Lladó
    • Vic, CATALONIA
    • Posts 18
    • Points 230
    Anybody from Avid out there?
  • Mon, Nov 5 2018 3:15 PM In reply to
    • Posts 10,156
    • Points 217,355
    Apologies but I was out of town this weekend.
    This has been reproduced and is logged as a bug MCDEV-9570 - engineering is working on it but it is still an open bug.
  • Mon, Nov 5 2018 3:55 PM In reply to
    • Sergi Lladó
    • Vic, CATALONIA
    • Posts 18
    • Points 230
    No problem Marianna, thank you for aswering.
    Do we know if this bug is with all blackmagic products? I mean, with which setup the bug was reproduced? I need very badly to work with an eficient monitoring workflow and if there's some blackmagic card that is tested to be working I'd buy it, because I'm in the middle of en edit of a tv program and we need to output the avid signal.
    Thank you!
  • Mon, Nov 5 2018 4:24 PM In reply to
    THANK YOU MARIANNA!  Do you recall what the last version of MC was that did not have this bug?  If we need to downgrade to an earlier copy of MC in order for our BM hardware to function properly, I'd rather do that then struggle with crashes.  This has been happening to me since 2018.8, and previously I ran 2018.3 for much of the year without BM problems.  So I would assume it happened somewhere between those versions.
  • Mon, Nov 5 2018 4:59 PM In reply to
    • Posts 10,156
    • Points 217,355
    2018.7 is when this started and was reported between that version and 2018.8
  • Mon, Nov 5 2018 5:22 PM In reply to
    Thanks!  I will downgrade at the next opportunity and see if that helps.
  • Thu, Nov 29 2018 2:08 PM In reply to
    Marianna,
    Just an update...  I upgraded to 2018.11 and I haven't had issues with VDM3BobVideoOut errors and the most recent BM driver.  BUT, I still struggled with laggy performance.  For me it seems, MC 2018.11 is prone to drifting out of sync with audio as the frame rate slows, then never catches up.  So I downgraded to 2018.5 and while there are certainly quirks (the "dual copy engine color inversion" annoyance) I've run into something that I can't fully explain.
    So when I open one of my older projects cut in MC 2018.10 (the same project that gave me these VDM3BobVideoOut errors) I have two sequences that aren't behaving like the others.  (FYI -The sequences are copies and contain the same media and effects.)  I can drag my position bar through the timeline and the composer window monitor doesn't update.  There are also strange redraw issues with the composer window, so it's not just BM hardware here.  If I switch to a different sequence in the same project, everything works perfectly fine as expected.  (In fact, If I switch to a completely different project using the same user setting, everything is normal, so it is definitely contained to this project.)  I've tried switching users and creating new users, deleting site settings and project xml prefs, even unticking that little checkbox under General>enable caps lock protection and rebooting.  Nothing works.  This is an issue that seems to be sequence-oriented, but does not manifest itself project wide or system wide.
    Any thoughts on what else I might try?  Thankfully this production is wrapped, but I'll most likely have to dive into it again Feb/March 2019 for updates so I'd like to know what to do to fix the project if it becomes a problem.
