Latest post Sun, Nov 11 2018 1:22 PM by Rinso Video. 10 replies.
Page 1 of 1 (11 items)
  • Sun, Nov 4 2018 12:51 PM
    MC 2018.10 media export violation
    Media Composer 2018.10
    Exception Structured Exception String Acces Vilation
    an exception when attempting to export media
    what is an string access vilation and how to fix it
    thanks
  • Mon, Nov 5 2018 5:21 PM In reply to
    • Posts 10,087
    • Points 216,565
    Re: MC 2018.10 media export violation
    Rinso Video:
    thanks
    Can you post the exact error as there should be digits after the Violation......
  • Mon, Nov 5 2018 9:01 PM In reply to
    • cls105
    • los angeles
    • Posts 404
    • Points 5,210
    "export media"... can you be a little bit more specific about this?  There are probably 100 export settings (when including custom codecs) after clicking export.
    what are you exporting and what settings?
    If you're exporting to quicktime.  I can say exporting with avid media processor or op1a MUCH better than exporting to quicktime.
    MC 2018.12.1, diy x299 7940x 4.5ghz OC, 1080ti, 128gb ram, w10 pro (1803) DM me on instagram for tech Q's: dvhaime [view my complete system specs]
  • Tue, Nov 6 2018 3:33 AM In reply to
    Marianna:
    Mariann
    File -Output- Export to File
    for example :-
    QuickTime Reference DV Codec
    Untitled Sequence  01
    Crash Report
    Exceptiom Structured Exception
    Excemption Code 3221225477
    followed by an mile long fault address
    and an long File Name   ...
  • Wed, Nov 7 2018 10:09 PM In reply to
    • cls105
    • los angeles
    • Posts 404
    • Points 5,210
    Did you attempt to export ama?  This will most likely solve your problem.
    Quicktime's latest version is from 2009.
  • Thu, Nov 8 2018 1:19 PM In reply to
    cls105:
    issue resolved thanks for the interest no further action requested pls close ..
  • Thu, Nov 8 2018 3:55 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,491
    • Points 64,420
    Rinso Video:
    I'm having the very same error, MC 18.10, QT ref same as source export. Would You mind sharing the magic to resolve the issue? :-))
    Symphony 2018.9, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
  • Fri, Nov 9 2018 3:03 AM In reply to
    luca.mg:
    Best guess is an Avid internal coding issue and the Code Error is now fixed maybe
    Only Avid knows what an Account Violation Fault Address 000 000 000 IC4 and Exception Code 3221225477 really is
     love to share some magic  a clean install of the current MC 2018 from the Download Centre is working at least for now so maybe it is fixed ...?
  • Fri, Nov 9 2018 4:55 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,491
    • Points 64,420
    I'm on o clean install, as far as possible: I always uninstall the old version and manually delete whatever Avid related is left in the HD before installing the new release. And I forgot to mention that this is happening on both my two systems. I'd love to provide the dump, but I don't know where it is located.
    peace luca
  • Fri, Nov 9 2018 6:17 AM In reply to
    Keith ...
     I posted the error Message to Marianna  there has been no reply to date from Avid ...
    far as aware the current Version of MC 2018 is working ok now which leads me to maybe Avid may have a fix..
    like to be more helpful however I have developed the "wipe it all and start again approach "
    life wasn't ment to be easy Geeked
  • Sun, Nov 11 2018 1:22 PM In reply to
    Rinso Video:
    Keith ...
    correction :- gone again
