Latest post Thu, Nov 22 2018 1:13 PM by timvertigofilms. 18 replies.
Page 1 of 2 (19 items) 1 2 Next >
  • Mon, Nov 5 2018 4:23 AM
    Crashes in trim mode when I have caps lock on
    I've been getting very frequent freezes when doing things in trim mode, where suddenly I get the rainbow wheel in the middle of a trim, and nothing happens no matter how long I wait, forcing me to crash out. I finally figured out that the problem goes away when I don't have caps lock on, but unfortunately I really rely on being able to audio scrub, and I keep turning it on by mistake and getting the stupid crash.
    Has anyone else experienced this and figured out a solution?
    I'm on Media Composer 2018.10.0, on a 2014 Macbook Pro, OSX 10.13.6, 2.8 ghz Intel Core i7, 16gb memory, NVIDIA GeForce GT 750M 2048 MB Intel Iris Pro 1536 MB.
  • Mon, Nov 5 2018 4:04 PM In reply to
    • Posts 10,157
    • Points 217,360
    Re: Crashes in trim mode when I have caps lock on
    Kevin,
    We are working on this one as jim Blokland reported it. I did create a case for you on this as it gets more visibility in engienering when there are more cases on the same issue.
    Case # 03585544
  • Mon, Nov 5 2018 5:03 PM In reply to
    Having the exact same problem with the current version of Avid MC. Everytime I trim and crash I look down and I've got Caps Lock on...everytime.
    Media Composer 2018.10, Mac Pro 5.1 2012 2.4 ghz, 64 GB ram, OSX 10.12.6, dual Nvidia 980ti 6GB gpu
  • Mon, Nov 5 2018 5:13 PM In reply to
    • Posts 10,157
    • Points 217,360
    threedogsonesnake:
    Aaron,
    I created a case so you are contacted by support....
    03585638
  • Mon, Nov 5 2018 7:55 PM In reply to
    • Nils S
    • Joined on Sun, Apr 15 2018
    • Posts 9
    • Points 155
    Hi Marianna,
    if support has a magic sauce (like, a hotfix?), could you please add me to the list?
    I've been hit by this as well :-/
    Thanks Yes
    Nils
    Retina iMac Late 2014, i7, 32GB, running macOS 10.14.1 & MC 2018.11 [view my complete system specs]
  • Wed, Nov 7 2018 12:28 AM In reply to
    I tried uninstalling the Blackmagic software that I have to use my Ultrastudio Mini Monitor, and so far have not had any crashes. Strange, though, since I've had this installed since 2015. And because I need to software to monitor video, I still need to figure out a solution.
  • Wed, Nov 7 2018 7:49 PM In reply to
    Well, since uninstalling Blackmagic I was doing pretty good, but just now got the same crash in trim mode. So it's not conclusive.
  • Wed, Nov 7 2018 8:45 PM In reply to
    I can safely say that the problem is absolutely tied to caps lock being on, however.
  • Tue, Nov 13 2018 1:45 AM In reply to
    • Laurent
    • Joined on Tue, Nov 13 2018
    • Montreal
    • Posts 1
    • Points 5
    I have the exact same problem. I'm only able to reproduce the bug by having caps lock on, otherwise I don't.
    It's very frustrating, because even though my autosaves are set to 5min, I can lost up to 15min of works like if the autosave didn't work properly... but that's another case...
    MC 2018.11, Mac Pro 6,1 (6-Core, 64GB, D500) on macOS 10.13.6Blackmagic UltraStudio mini monitor for playback [view my complete system specs]
  • Tue, Nov 13 2018 2:58 PM In reply to
    • Posts 10,157
    • Points 217,360
    Nils S:
    Hi Marianna,
    Thanks Yes
    Nils
    Nils
    I have a case created for you...  # 03591441 and support will keep you in the loop.  MCCET-2722 is the bug and it is being worked on currently.
  • Tue, Nov 13 2018 2:59 PM In reply to
    • Posts 10,157
    • Points 217,360
    pretzelcuatl:
    Kevin....
    It is a bug MCCET-2722 and there is a case for you already started....   03585544
    Engineering is working on it.
  • Fri, Nov 16 2018 10:01 PM In reply to
    • Thomas
    • Joined on Sun, Feb 23 2014
    • Cologne
    • Posts 46
    • Points 645
    This seems to be a Software-Bug in 2018.10 (Mac and Windows) with and without any Breakoutbox.
    It is absolutely reproducable. Just make a Cut in any material. It even can be offline-material! Then trim forward-backward. Play arround with the Trim-function. So far as good. Do not deactivate the Trim-function. Now activate the audio-scrubb by the caps lok key and now play arround with the trim-function. The Trim beginns to slide very slow the audio get lost (even if you leave the Trim-function the audio is lost probaply the MC-mixer-service stopped until restart the application). When the trimm hangs - Avid has crashed. If not it will crash some time later. It can crash with or without any error message, spontanously. See the following picture:
    LINK Our Cutter deactivate the Breakoutbox in the hope to cut without any crash, but it crashs too. So who needs it have to downgrade to an earlier MC.
    several Avid Workstations, Baselight One [view my complete system specs]
    Thomas Poerschke, Editor & Colorist
    ColorGrading.TV @ MMC Studios Köln, Am Coloneum 1, 50829 Cologne, Germany
    web: www.colorgrading.tv
  • Fri, Nov 16 2018 10:14 PM In reply to
    • Posts 10,157
    • Points 217,360
    Yes this is a confirmed bug and the engineers are still working on it.  still not fixed yet in the build of software.
    MCCET-2722
  • Sun, Nov 18 2018 4:55 PM In reply to
    Thomas:
    Just tried and couldnt reporduce.
    With and w/o ultrastudio on - OSX 10.14 and MC 2018.10 caps lock on and also with using sfift key held down for scrub. Smooth as butter.
    iMAC (late 2015) 4GHZ i7 - 32GB RAM - AMD R9 M395X 4GB 512 SSD BOOT BM Ultra Studio Express w/Driver 10.5.4. [view my complete system specs]
  • Sun, Nov 18 2018 4:56 PM In reply to
    forgot to mention most recent blackmagic crivers too.
