Latest post Fri, Nov 9 2018 9:17 PM by hbrock. 1 replies.
Page 1 of 1 (2 items)
  • Thu, Nov 8 2018 7:58 PM
    synced clips in the source monitor get out of sync when in the timeline
    Hello there,
    Another issue today that I've never seen before in Avid.
    Basically I have a bunch of Slow Motion Clips (50FPS) that need to be synced in Avid. So I do, as usual, make them 25fps then sync them in the timeline then subclip. Everything good, they sync, I see the clip in the source monitor and check the clip, and it is perfectly synced.
    But, and now comes the weird thing, when I import that clip into the timeline, the clip gets out of sync.
    Why is that? What am I doing wrong here?
    Can someone please give me some help to resolve this issue?
    Thank you so much in advance.
    All the best,
    Chiara
  • Fri, Nov 9 2018 9:17 PM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,520
    • Points 64,055
      Moderator: MCA Mac
    Re: synced clips in the source monitor get out of sync when in the timeline
    Synced clips can only play the audio and video at the same rate.  You can't have a motion adapter applied to the video and play the synced audio at a different rate unless you...
    1. Sync the clip with the motion adapter but replace the video with a video mixdown before committing the synced clip.  Note: you won't be able to go back to the source material if you do this.
    2. Sync the audio to the motion adapted video on the timeline and don't try to make it a synced clip.
