Latest post Fri, Nov 9 2018 9:04 PM by hbrock. 4 replies.
  • Fri, Nov 9 2018 4:25 PM
    • sbomse
    • Joined on Thu, Sep 20 2007
    • Posts 29
    • Points 385
    problem with Quicktime Reference
    I'm trying to make a Quicktime Reference in order to bring that into Media Encoder and have Encoder make an h264 file there.
    My footage is 4K but I've made a video mixdown in Avid - that also has 4K dimensions of 4096x2160.
    The problem is more often than not the Quicktime Reference comes out with no video.  Sometimes I've been able to export a small piece of the sequence that comes out correctly but usually not.
    Any thoughts?   Very frustrating.
    Thanks.
    Seth
  • Fri, Nov 9 2018 6:03 PM In reply to
    Re: problem with Quicktime Reference
    If you have a mixdown then why not do a same as source export as a complete file and skip the ref ?
  • Fri, Nov 9 2018 8:42 PM In reply to
    • sbomse
    • Posts 29
    • Points 385
    Thanks for your response.  A same as source will be too big.  I'm trying to make a compressed h264 file.  Avid takes so long to do that I was trying to use Encoder in the background from a Ref.
  • Fri, Nov 9 2018 9:02 PM In reply to
    • GT
    • South Africa
    • Posts 386
    • Points 4,215
    Adobe Media Encoder no longer supports QT Reference files - see here:
    https://helpx.adobe.com/x-productkb/multi/quicktime7-support-dropped.html
    The 2017 version still works.
    MC Ver 8.7, Intel Core I5, NVidia Quadro FX 570, 16Gb Ram, 250 Gb system drive, 2 Tb Render/Media drive, Windows 7 64bit Pro, QT 7.6.6 [view my complete system specs]
  • Fri, Nov 9 2018 9:04 PM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,520
    • Points 64,055
      Moderator: MCA Mac
    I've seen the same problem on multiple systems.  The weird thing is that some systems always work and others work (or don't work) randomly.  If your QT reference works in other encoding programs like Compressor or Squeeze then it would seem to be an Adobe question.
