Hello.
I just downloaded Pro tools first as it was bundled with the focusrite 2i2 i bought,
however whenever I start Pro tools it comes up with an error and closes immediately afterwards.
This is the error:
Could not complete your request because Assertion in "D:\ Code\ 223093\ ProTools\ AAE\ Source\ AAX\ CFicAAXWidget.cpp", line 851.(Use the Copy button to copy this message to the clipboard.).
I have tried to hold N on startup to get to the playback engine however this just causes the software to crash.
I'm using windows 10. Any help on the situation would be greatly appreciated.Thank you
Hi
This is the Video Pro Community, for Audio related issue please go to the DUC.
You can also email me include the PT systems ID I will connect you to our PT team.
RalphC
Thank you for your quick reply but I've managed to solve the issue by downloading the oldest possible version of ptf I could find, apparently the software actually works on that one! i just hope updating it wont stop it working again. thank you.
Hello I am having the same issue.. what is wrong with software these days . it takes 1 whole day to install software.
What Am I suppose to do with this useless informational error?
Provide a link to click to fix this issue.
Im on a windows 10
This is the Pro Video Community Forums, for Audio related please go to the DUC.
I wish they would actually give you advice to solve these issues then just telling you its the wrong place to post.
This link is the pro tools first downloads page it has older versions on it.
http://esd.avid.com/ProductInformation.aspx?id=115
I downloaded the oldest one, set everything up in that and then updated to the new pro tools when it prompted to update, it worked for me after that.
If your like me and got Pro tools first with a focusrite scarlett then i just advise using ableton instead seems much easier can use most plugins and actually works on start up.
Hope this helps anyone with the same issue!
R.Wilko:I wish they would actually give you advice to solve these issues then just telling you its the wrong place to post.
I'm very sorry about that, but as you can see this section of the Forums is dedicated for video related stuff only higher percentage of the poster here uses Media Composer, few I know use both but still we encourage users to post to Duc if it's an Audio concern to get better attention.
