Latest post Fri, Nov 16 2018 9:12 PM by DJFio[DB]. 4 replies.
  • Thu, Nov 15 2018 8:45 AM
    • DJFio[DB]
    • Joined on Thu, Nov 3 2005
    • Moscow Russia
    • Posts 272
    • Points 3,590
    AMA link with network drives - gives Media Offline MC2018.10
    After installing 2018.10 - all media files AMA linked from network drives (SMB, AFP) gone offline.
    in MC 2018.9 and earlier works and online as expected.
    alldrives does not help.
    Maybe a new feature in mc 2018.10?
    temporary solution is to connect all drives locally or move everything to NEXIS.
    my zoo: NEXIS Pro 40 tb sw v18.6.1; MBPro_late_2013 15'' i7 16GBram OSX 10.12.6 MC 2018.12.1 BMD US monitor (or AJA io XT ), EXT thunderbolt NvidiaGPU... [view my complete system specs]
    DJFio[DB]
  • Fri, Nov 16 2018 6:39 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,518
    • Points 64,035
      Moderator: MCA Mac
    Re: AMA link with network drives - gives Media Offline MC2018.10
    Did your AMA Management folder get deleted? It's usually found in Users/Shared/AvidMediaCompser.  It keeps the database for linked files.  If it's gone, the clips will remain in a bin but the files will be offline until you link to the sources again.
  • Fri, Nov 16 2018 5:33 PM In reply to
    • DJFio[DB]
    • Moscow Russia
    • Posts 272
    • Points 3,590
    i experimented with deleted and not. Same result 18.10-offline, 18.9 - online.  Freshly linked files - appears offline in 18.10.
    DJFio[DB]
  • Fri, Nov 16 2018 7:19 PM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,518
    • Points 64,035
      Moderator: MCA Mac
    Suggest you contact Avid support and open a case.
  • Fri, Nov 16 2018 9:12 PM In reply to
    • DJFio[DB]
    • Moscow Russia
    • Posts 272
    • Points 3,590
    I'll just wait for the upcoming 11 release :) and only then ....
    DJFio[DB]
