Latest post Wed, Nov 28 2018 5:07 PM by derekg. 6 replies.
Page 1 of 1 (7 items)
  • Mon, Nov 19 2018 7:20 PM
    • dew
    • Joined on Tue, Feb 27 2007
    • Posts 508
    • Points 6,525
    AAF timeline into resolve
    Hey I am trying to send a aaf timeline into resolve from Avid media composer. The footage in MC is AMA linked. When imported in Resolve the media is offline and there is a message saying there is a mismatch between the specific targeted timecode and the located timecode. Any idea of what may be causing this? Is it the canon folder structure at it has multiple folders in it.
    Avid MC 8.8
    Resolve 12.5
    Canon c100 folder structure
  • Mon, Nov 19 2018 8:57 PM In reply to
    • Martin Fox
    • Joined on Fri, Mar 14 2014
    • Sydney Australia
    • Posts 219
    • Points 2,315
    Re: AAF timeline into resolve
    Try importing a used clip directly into resolve and compare the timecode at a known point with the timecode in Avid , to be sure they are the same.
  • Tue, Nov 20 2018 12:36 AM In reply to
    • DStone
    • Massachusetts
    • Posts 3,527
    • Points 45,365
    Here's a link to round tripping to resolve which may help.
    http://www.avidblogs.com/how-to-roundtrip-davinci-resolve-to-avid-media-composer-tutorial/
    Dave S.
  • Tue, Nov 20 2018 7:27 PM In reply to
    • derekg
    • Los Angeles
    • Posts 43
    • Points 580
    I see it's C100 footage. I've had the same problem and it's a Resolve rather than Avid problem. Resolve has problems with AVC timecodes. It doesn't read spanned files correctly (ie any file over 11mins) and then all the other codes on that card are incorrect. I've even had a problem when recording a file on one day and then continuing on the card a couple of days later resulted in all the later clips having wrong timecodes. You can easily check by comparing the timecodes in the Resolve Media Pool clips with the same clips in Avid. I've always found that Avid reads everything correctly, even checking by comparing timecodes on the card in the camera.
    I've actually given up trying to get Resolve to relink to C100 camera files and just transcode my finished Avid timeline and work on the transcoded files in Resolve.
    Derek Goodall
    Goodwood Productions, North Hollywood CA
    HP z420 3.6 Xeon quad core, 32GB RAM, Nvidia GTX660, BM Intensity 4k, Win 10 [view my complete system specs]
  • Wed, Nov 28 2018 11:24 AM In reply to
    • dew
    • Posts 508
    • Points 6,525
    derekg:
    Derek Goodall
    Hmmm interesting. Im going to try the workflow mentioned above and if that doesn't work then I will look into transcoding.
  • Wed, Nov 28 2018 12:03 PM In reply to
    • dew
    • Posts 508
    • Points 6,525
    Derek you are right. Once I transcoded the footage it worked flawlessy.
  • Wed, Nov 28 2018 5:07 PM In reply to
    • derekg
    • Los Angeles
    • Posts 43
    • Points 580
    Glad that worked for you. Unfortunately Blackmagic dont seem to regard AVC as a format they need to bother about, particularly regarding timecode.
