Latest post Wed, Nov 21 2018 5:54 PM by rafal_mc. 2 replies.
  • Wed, Nov 21 2018 8:36 AM
    • rafal_mc
    • Joined on Tue, Nov 20 2018
    • Posts 2
    • Points 20
    Avid Not Recognizing Activated License
    HI.
    Sorry for my English.
    Such a problem.
    I connected the third monitor. Avid can not start, the activation window is activated.
    The app manager says that my Avid is activated
    I'm dead in the moment, and I've got to work to ... :-(
    Rafal
  • Wed, Nov 21 2018 2:27 PM In reply to
    • Posts 10,159
    • Points 217,400
    Re: Avid Not Recognizing Activated License
    Can you email me your system ID and MYAvid email please
  • Wed, Nov 21 2018 5:54 PM In reply to
    • rafal_mc
    • Posts 2
    • Points 20
    Normal 0 21 false false false PL X-NONE X-NONE MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:Standardowy; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
    HI. Marianna
    Thank you for the information.
    Already OK - I received information from avid support on what to do.
    Case closed.
    Please try this workaround, Close Media Composer and Application Manager then Delete these folders:
    for Windows
    C:\ProgramData\Avid\Licenses
    C:\ProgramData\Avid\SWL
    C:\ProgramData\Avid\Common
    C:\ProgramData\Pinnacle\Pixie
    for MAC
    HD\Library\Application Support\Avid\Licenses
    HD\Library\Application Support\Avid\SWL
    HD\Library\Application Support\Avid\Pixie
    Afterwards, delete the Application manager cache and DB
    [1] Quit out the Application Manager and in your Activity Monitor or Task Manager end or quit the process of AvidAppManHelper and Avid Application Manager
    [2] Delete Caches and Db
    On Windows:
    C:\ProgramData\Avid\AppManager\(delete Caches and Db)
    On Mac OS X:
    /Library/Caches/Avid/AppMan/(delete Caches and Db)
    [3] Open AvidAppManHelper first before Avid Application Manager
    On Windows:
    Go to C:\Program Files (x86)\Avid\Application Manager\Run AvidAppManHelper then AvidApplicationManager
    On Mac OS X:
    Go to Macintosh HD/Applications/Avid/Application Manager/Run AvidAppManHelper then AvidApplicationManager
    Note: It's normal that there's no window will pop up or open if the AvidAppManHelper is clicked, we just need to trigger it first to enable the AvidAppManager
    Reopen Media Composer and Activate.
    Thank you!
