Latest post Fri, Dec 14 2018 12:22 PM by nateliv. 3 replies.
  • Fri, Nov 23 2018 2:01 AM
    • FWEditor
    • Joined on Fri, Nov 23 2018
    • Posts 2
    • Points 30
    Exception: failed to get the sample position from the AMA plug-in
    Hi.
    I get the above error on a project that i have completed and wanted to archive, but every time i try to consolidate, it gives me the above error.
    Any ideas? Is it a file structure problem, or a functionality problem?
    I'm on 8.9.3
    thanks.
  • Fri, Nov 23 2018 8:07 AM In reply to
    • TrevorA
    • Posts 1,081
    • Points 12,305
    Re: Exception: failed to get the sample position from the AMA plug-in
    I had this error in 2018.x & found a recommendation to delete AMA management folder - worked for me
  • Fri, Nov 23 2018 11:08 PM In reply to
    • FWEditor
    • Posts 2
    • Points 30
    I'll try it next time.
    This time I handled it, turns out it was a corrupt clip.
  • Fri, Dec 14 2018 12:22 PM In reply to
    • nateliv
    • Joined on Fri, Dec 14 2018
    • Posts 4
    • Points 25
    Can't even AMA link to it. You'll need to use Resolve or EditReady to convert it to an editable format. If you are working offline/online, then that means that that newly converted footage will be the master, and you'll need to transcode that to offline, or you'll need to online in Resolve (if you use Resolve to transcode)
    Bluestacks TextNow VPN
