Latest post Thu, Nov 29 2018 2:16 PM by Jeroen van Eekeres. 6 replies.
Page 1 of 1 (7 items)
  • Tue, Nov 27 2018 10:01 PM
    Add DNxHR uncompressed formats to disabledres.txt
    Dear Avid,
    I'd like to know what text needs to be added to the disabledres.txt file to prevent media composer from selecting these formats in media creation.
    While the formats were added to MC, the doc regarding disabledres:
    http://avid.force.com/pkb/articles/en_US/troubleshooting/en263605
    was not updated with the newly added formats.
    Thank you.
    Avid reseller ACSR at Telmaco
    http://www.telmaco.gr/en/
  • Wed, Nov 28 2018 5:53 PM In reply to
    • NYnutz
    • Joined on Wed, Nov 25 2009
    • New York City
    • Posts 349
    • Points 4,095
    Re: Add DNxHR uncompressed formats to disabledres.txt
    These are the entries, tested with mc2018.11 on win10 in 1080i5994 and UHD 2997p projects:
    #DNxUncompressed 4:2:2 8bit MXF
    #DNxUncompressed 4:2:2 10bit MXF
    #DNxUncompressed 4:2:2 32bit float MXF
    remove "#" to diable.
    Dave
    "A very big network"
  • Wed, Nov 28 2018 5:58 PM In reply to
    • NYnutz
    • New York City
    • Posts 349
    • Points 4,095
    For RGB format projects:
    #DNxUncompressed RGB 8bit MXF
    #DNxUncompressed RGB 10bit MXF
    #DNxUncompressed RGB 32bit float MXF
    update: also tested with 23.976 1080p and UHD projects.
    Dave
  • Thu, Nov 29 2018 7:14 AM In reply to
    Thx NYnutz.
    If it were that simple I would not have asked. Adding those does not remove them over here on 2018.11 from the available formats. Obviously there is an abbreviation used or something. In case of the 'new' AVC Long GOP 6 format the existing syntax was followed and adding that to disabledres.txt couldn't be simpler. But not in case of these uncompressed formats.
  • Thu, Nov 29 2018 7:33 AM In reply to
    Ok I'm being stupid.
    If I remove the MXF at the end it works correctly
    Thanks NYnutz
  • Thu, Nov 29 2018 1:53 PM In reply to
    • NYnutz
    • New York City
    • Posts 349
    • Points 4,095
    Moving from previous versions of media composer, some "disabled" resolutions became enabled when avid appended "MXF" to the codec name. For my own sanity in maintaining the list, i've decided to keep duplicates of the resolutions in my disabledres, one set with "MXF" appended, and one set without. YMMV based on what version of media composer you are using.
    Dave
  • Thu, Nov 29 2018 2:16 PM In reply to
    NYnutz:
    No way!!! Omg Avid. Thanks NYnutz as I didn't know that.
    Avid is indeed playing with our sanity.
