Latest post Wed, Dec 5 2018 12:35 PM by Adrian Redmond. 6 replies.
Page 1 of 1 (7 items)
  • Tue, Dec 4 2018 6:57 PM
    • Adrian Redmond
    • Joined on Wed, May 28 2014
    • Posts 38
    • Points 475
    Moving a clip vertically on the timeline
    I often need to move a clip - typically an audio clip - vertically on the timeline, from one track to another. This is often, though not always caused by the fact that Avid forces me to lay a clip on to a specific track, after which I might want the clip to lay on another track. This need may arise either when the audio clip is the same length as it's appropriate video clip, or after I have edited, so that the audio clip in or out point extends before or after the in/out point on the video clip.
    I find that when using the mouse and simply moving the clip vertically, it almost always lands between 1 and 4 frames out of sync to the audio/video clip to which it belongs, necessitating a time-consuming zoom in on the timeline to see the correct position.
    Is there a simple keyboard shourcut when moving a clip vertically that prevents the clip being moved from moving horizontally - or that "magnets" the clip being moved to it's partner?
    Any words of wisom out there?
    Avid Media Composer v. 8.5.3. with Symphony Option on HP Z820 Dual Intel E5-2640 6 core HT 2.5GHz CPU 32GB RAM NVidia Quadro K4000 Graphics External storage... [view my complete system specs]
  • Tue, Dec 4 2018 7:10 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,598
    • Points 60,090
    Re: Moving a clip vertically on the timeline
    You can hold the CTRL key down while moving the clip up/down and it will snap to the head of the video track (or to other edit points in active tracks). See if that works?
    Note also that the playhead can be used as a target for snapping in this way so you can park it where you need it and then drag other clips with the CTRL key held down and they will snap to the location of the playhead.
    Camera(s) PXW-X70, HDR-FX1, Hero 6 Black | MC 18.7 | QT 7.7.9 | BCC 11 | Sapphire 11 | Mocha Pro 5.6 | Titler Pro 6 | Windows 10 Pro x64 | System: P6X58D... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Tue, Dec 4 2018 7:27 PM In reply to
    In Media Composer 8.9.3 they added buttons that allow you to move clips vertically.
    Command palette > Edit tab > Move Clip Up/Move Clip Down
    (Just in case you didn't know.)
    Media Composer 2018.11 w/Symphony/SS/PF options, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce... [view my complete system specs]
  • Tue, Dec 4 2018 8:29 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,598
    • Points 60,090
    You are correct! By default it maps to the up/down arrow keys. If you hold the CTRL key then the clip is duplicated... Very useful indeed.
    Steve
  • Tue, Dec 4 2018 9:15 PM In reply to
    • Ken Lent
    • Joined on Tue, Dec 18 2007
    • California
    • Posts 120
    • Points 1,270
    SHIFT+CTRL+drag => move clip, vertically only
    SHIFT+CTRL+ALT+drag => copy clip (preserving original), vertically only
    Core i7 930 PC 2.8GHz / 18GB RAM / Win7 Pro 64bit SP1 / nVidia Quadro K2200 (driver 375.86) / MC 8.8.5 (Symphony/PF/SS) / BCC AVX 10.0.2 / NewBlue Titler... [view my complete system specs]
  • Wed, Dec 5 2018 12:35 PM In reply to
    • Adrian Redmond
    • Posts 38
    • Points 475
    I'm running v. 8.5.3. which unfortuneatly doesn't have these options :)
    • Adrian Redmond
    • Posts 38
    • Points 475
    Nice Ken - this works for me - thanks!
