Latest post Sat, Dec 8 2018 3:39 PM by Telegram!. 1 replies.
Page 1 of 1 (2 items)
  • Sat, Dec 8 2018 10:23 AM
    • OwenP
    • Joined on Thu, Oct 12 2006
    • London, UK
    • Posts 12
    • Points 180
    Grouping or Multicam 4K rushes with HD Rushes
    Hi All,
    I'm about to start an 1080/25p documentary project.
    Our main interview 'A' camera will be shooting 4K and our 'B' cam will shoot HD.
    Worked well on our last project as we were able to 'punch in' on the 4K shots for CUs.
    At the offline stage we just ingested everything, including the 4K material, into an 1080/25p project. This worked flawlessly but the resizes of the 4K rushes looked terrible, of course, because they were DNx36. And it's the image quality of the 'punch ins' at the offline stage that I'm hoping to improve this time around.
    So this time I thought I'd try ingesting the 4K rushes into a 4K project and then opening those bins in the main 1080/25p project and working with them that way. (probably at LB or maybe SQ quality)
    I did a quick test before leaving work yesterday and it seems to work the way you would expect. I have timeline access to the 4K clips Frameflex settings, so I can punch in as I expected and at first glance it appears better quality.
    However, before I commit to ingesting 20+hrs of 4K footage though, I wondered if anyone has experience of grouping or multicam'ing mixed format/resolution rushes this way?
    In other words 4K rushes ingested into 4K project, then opened in an HD project and then Grouped or Multicamed with 'B' cam 1080p DNx36 rushes.
    I'll be doing some tests on Monday but I thought I'd see if anyone had experience of doing this on a longform project over several months and whether they'd run into any performance issues, online conform issues etc.
    I don't even know if there is an image quality benefit in doing it this way but it's worth a try.
    Thanks all
    Owen
    Macbook Pro, BM Intensity [view my complete system specs]
    Filed under: , , ,
  • Sat, Dec 8 2018 3:39 PM In reply to
    Re: Grouping or Multicam 4K rushes with HD Rushes
    Just a thought:
    Is your system able to offline edit smoothly at your intended HD output resolution?
    If so, how about you Transcode from 4K links to your Full wide and also your Punch-in,
    add your other HD angle; but also add the originating 4K link to your Group Clip (but taken Offline during rough editing)
    so that it’s potential for re-positioning and zooms Via Frameflex is there if and when you need it?
    Could that work?
    Also: What version of MC are you interested in doing this edit with?
    This may be pertinent:
    http://community.avid.com/forums/t/184275.aspx
