Latest post Sun, Dec 16 2018 5:26 AM by tommix. 5 replies.
Page 1 of 1 (6 items)
  • Thu, Dec 13 2018 12:10 PM
    • tommix
    • Joined on Tue, Oct 14 2008
    • Posts 207
    • Points 2,545
    Still not fixed -- cannot PUBLISH
    Hi Marianna,
    HELP PLEASE
    We all get the same eror messages. Failing since July.
    I write for TheBroadcastBridge and reference MCF a lot.
    If this isn't fixed in 2018.12 I really have no choice but to switch to Resolve with a very public note as to why I'm changing my reference NLE. With these error messages it really can't be that hard to find and fix.
    Steve Mullen -- from the good old days
    The second appears when I click "Continue"
  • Thu, Dec 13 2018 4:47 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,501
    • Points 45,075
    Re: Still not fixed -- cannot PUBLISH
    Steve,
    What is the system spec's of the machines in question? And what version of Windows are you running (if it's 1809 there may be issues). You may also try re-installing the QT runtimes, just to see if that helps (eventually all of QT will be gone from MC).
    Dave S.
  • Fri, Dec 14 2018 2:09 AM In reply to
    • tommix
    • Posts 207
    • Points 2,545
    Version 1803.
    If 1809 is the "next" version being rolled-out I have put a delay on it so my PC will not be auto updated. But, when will 1809 be suported?
    PC, Windows Home, i7, 16GB RAM, GTX1080 -- same system I've had since MCF first was roled-out.
    I'll re-install OT.
    I'm writing a 3-part series for TBB on using Resolve for color grading with MCF as the NLE. Used MC since 1994 and do not want to edit with Resolve!
    Thank you.
    PS: You do not have to give up on using MCF.
    1) Mixdown video.
    2) Mixdown audio.
    3) The two or three files will be in your AvidMedia folder.
    4) Drop them into another NLE. I use Resolve.
    5) Export your movie as DNxHD or ProRes.
    6) If needed, upload DNxHD or ProRes to YouTube or Vimeo. Let them do the single compression to h.264.
  • Fri, Dec 14 2018 7:23 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,501
    • Points 45,075
    Well, your system should certainly support MCF. It really sounds like a QT interaction issue. If it continues after re-installing QT, try uninstalling and re-installing MCF. After that, I'm out of ideas.
    Dave S.
  • Sat, Dec 15 2018 4:40 AM In reply to
    • tommix
    • Posts 207
    • Points 2,545
    I have installed -- which was an upgrade -- 7.79.0.95.
    Same immediate crash with the same error messages! Super Angry
    System has SSD (C:) internal HD and many USB drives.
    I assume MCF tries to write to C: or D:, but since there's no way of knowing -- who knows?
    WE DO KNOW THE BUG STARTED WITH THE RELEASE IN JULY.
    Thank you.
    Marianna HELP!
  • Sun, Dec 16 2018 5:26 AM In reply to
    • tommix
    • Posts 207
    • Points 2,545
    An error report from just before the crash:
    A longer repoert:
