Latest post Sat, Feb 2 2019 7:18 AM by bucur.marian. 26 replies.
Page 2 of 2 (27 items) < Previous 1 2
  • Sun, Jan 6 2019 8:29 AM In reply to
    • Schmidtsk
    • Joined on Thu, Jan 18 2007
    • McGregor, South Africa
    • Posts 106
    • Points 1,300
    Re: MC exports AAF not containing data
    Hello Avid.... Anyone listening?
    MC 2018.12 (Symph) on iMac 4.2. i7 40GB (OSX 10.14.2). Also MC 7.0.5 on MacPro 2.66 11 GB (OSX 10.7.5) [view my complete system specs]
    Plant a tree
  • Sun, Jan 6 2019 4:21 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,375
    • Points 40,765
    I am coming in very late on this, and may be redundent, but one thing I see in your screen shot is that you convert to AIFF-C. I have read somewhere else that there are issues with AIFF files in some later versions of MC.
    I make AAF files with Wave format.  I have made several in that last few days with no issues from 2018.11.
    Now, full disclosure, I am sending to Nuendo systems.
    But I think a quick test with Wave file format would be useful.
    Jef
    Jef Huey
  • Sun, Jan 6 2019 6:51 PM In reply to
    jef:
    I wondered about that and think it could indicate why most/all(?) the people posting about the issue are on Macs.  I can test this in a couple of hours.
    Thinking about it last night I thought a simple but maybe not popular solution could be Avid writing a simple standalone program that could split the media out of an embedded AAF to a user designated folder. The Pro Tools facility then copies the AAF, splits the media out of one and loads the other into Pro Tools.  The operator can then point the Pro Tools session to the split media folder.  I would imagine that this program would be tiny and could easily be sent along with the AAF.  Not Elegant but could be a very easy fix.
  • Sun, Jan 6 2019 7:28 PM In reply to
    • jef
    • Maryland
    • Posts 3,375
    • Points 40,765
    Alayne Holmes:
    jef:
    Not sure if this is what you mean, but rather than have Avid make an Embedded AAF, you can have it write the media to a folder.  The user then points to the folder when loading the AAF.  This was common when using OMFs which had a file size limit.
    Jef
    Jef Huey
  • Sun, Jan 6 2019 11:00 PM In reply to
    • palm
    • Joined on Mon, Aug 1 2011
    • Posts 7
    • Points 85
    Same here, embedded AAFs exported with 2018.11 won‘t open in ProTools but will open correctly when re-imported into MC for testing integrity. Nasty.
  • Sun, Jan 6 2019 11:12 PM In reply to
    jef:
    No not what I mean. One of the posters here (or the other AAF running concurrently) said they needed embedded media when the consolidate to folder was suggested.
    I was  suggesting a new standalone program, Made up basically of a UI, import AAF, predominantly the part of the code from the old AAF Pro Tools open that separates the media from the "timeline" data, a UI option for the user to create/select a media folder and copy the Media files with all their meta data to that folder.   If Avid wish to complicate this slightly the program could also create a new AAF (Linked media) using the folder it had just created.  In my opinion this may solve a lot of the Pro Tools operators problems when receiving AAF's from Premier and other NLE's as well.
  • Sun, Jan 6 2019 11:58 PM In reply to
    jef:
    Tested with Windows 10 MC 2018.12 exported AAF using embedded media converted to PCM(MXF)  Failed to find media with both Mac Pro Tools 11.1.3 and Windows 7 Pro Tools 10.3.10. Assumption that PCM audio is Wav file format and a little reluctant to get into omf specific wav files.
  • Fri, Jan 18 2019 4:40 PM In reply to
    • Fish
    • Joined on Sat, Oct 15 2005
    • Filet Post, Halifax NS
    • Posts 557
    • Points 6,780
    Just an update. I have the latest version of the software and an embedded AAF still does not import into Protools. But the AAF with a seperate media folder works fine.
    2012 Westmere MacPro 2 x 2.66 GHz 6-Core Intel Xeon) 6 GB 1333 MHz DDR3 ECC ATI Radeon HD 5870 1024 MB As of Jan 2015 - OS X 10.9.5 (13F34) [view my complete system specs]
    AVID man, AVID fan (since 1993 with version 4.5 - before multiple tracks!)...like to solve my own problems and I try not to bother anyone unless I'm really stumped.
  • Fri, Jan 18 2019 5:33 PM In reply to
    Is still an AIFF-C media issue? Does it work if you use WAV media?
  • Fri, Jan 18 2019 5:35 PM In reply to
    • Fish
    • Posts 557
    • Points 6,780
    I tried both...in the past. Not with this new version. With this latest attempt it was WAV.
  • Fri, Jan 18 2019 6:22 PM In reply to
    • John
    • Joined on Sat, Oct 23 2010
    • Miami, Florida
    • Posts 63
    • Points 790
    AVID is aware of the issue.  Case # 03628555
    Imacpro 10C, 64Gig, R64 - Decklink Monior [view my complete system specs]
  • Sat, Feb 2 2019 7:18 AM In reply to
    • bucur.marian
    • Romania
    • Posts 99
    • Points 1,250
    We have also a client affected by this and raised case 03641736.  The AAF exported by MC cannot not be open in MC 8.6 also. We found out that MC 8.6 can export the seqeunce just fine, so if you have a shared storage you can build a MC 8.6.5 just for AAF export
    Whatever the customer has :) [view my complete system specs]
    ACSR Elite
