Latest post Thu, Dec 20 2018 7:18 PM by George Angeludis. 6 replies.
Page 1 of 1 (7 items)
  • Wed, Dec 19 2018 8:57 PM
    HELP! Will send Candy! HELP! -- Strange green flashing in timeline
    Oh this is nuts.
    We have two HPZ840s with avid 8.4 connected to a SAN over Cat6.
    We have an artist box in one room and only software in the other room
    Each machine has like 32gb and 16 cores. Very straightforward system.
    All is working fine as we were sharing a project then suddenly poof, one of the rooms (the one that is just software) started inserting full frames of green that would flash as we played. The footage was shot AVC Intra 4k, 10 bit 4-2-2 and was transcoded to a rough cut format of 1080pm / 23.976 at DNx115. There is no AMA linking at all. No effects. No renders- nothing. Just hard cuts. The room with the artist box works fine. I doubt this is related to the artist box.
    We tried changing the little oval from yellow to green and the flashing would change each time. It might become pink with lines, and it one point I am convinced it was pulling footage in from another project. We have isolated that it is not the SAN. Other things run fine. Another crazy thing is that we took a single clip and added a visual time code over it and tried to render it and it the same error happened.
    We have been on with AVID tech support for two full days. They have accomplished exactly nothing. We have uninstalled and reinstalled everything. I am convinced there is a setting or group of settings we are missing here. Has anyone ever seen this? HELP!
    HP z840, with dual E5-2634 v4 Xeon processors at 2.2ghz (10 cores each). 32GB ram. NVIDIA m4000 video card. EVO SAN with 96tb and raid 5 over Cat6. Artist... [view my complete system specs]
    I think we need a few more digital HD formats
  • Wed, Dec 19 2018 9:43 PM In reply to
    Re: HELP! Will send Candy! HELP! -- Strange green flashing in timeline
    SO another thing -- there are long areas in the timeline that play as pure green. It is a bright green and can run for a minute or more before it goes back to video.
  • Wed, Dec 19 2018 11:31 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,569
    • Points 45,830
    Just for grins, go into Settings->Video Display and uncheck Dual Copy Engine. See if that help (or if it was unchecked you could try checking it).
    Dave S.
  • Thu, Dec 20 2018 1:26 PM In reply to
    Do you have any LUTS or colour adapters applied?  This can cause the effects you are having.....as I found out.   Do the clips playback green too?  If so remove the effect adapter from the properties.
    MC/SN 2018.6+7+8+9+12 x 16 Z400/420/440 PC's on W7 x64. 2 x Mac, 4 x PT 12.8.1 HDX, S6 all on PCs. ISIS 5000 X 2. [view my complete system specs]
  • Thu, Dec 20 2018 6:02 PM In reply to
    Hi
    None of the above. Other ideas? Avid tech support also made the changes to the video card.
    I dont know what to do... if AVID cannot help -- what other options are there (no jokes please)
  • Thu, Dec 20 2018 6:09 PM In reply to
    • Posts 10,219
    • Points 218,265
    Hey there
    Can you go to  your MC installer, and copy all the files in the Installers\MediaComposer\Program Files 64\Avid\Avid Media Composer\QuickTimeServer to overwrite the corresponding folder in your avid install (C:\Program Files\Avid\...) - EXCEPT for the Quicktime_OPServer.exe file. If you overwrite the Quicktime_OPServer.exe Avid will hang at the 'Initialising AVX2 hosts' on startup.  If you overwrite everything but that file, do you still get green flashes....
  • Thu, Dec 20 2018 7:18 PM In reply to
    Dual Copy is working at my P2000 (for example) and it can be enabled through quality options.
    If Dual Copy isn't supported it can't be enabled.
    To add to what M said try to reinstall the correct Nvidia drivers.
    Now that could be a good reason to use only a Quadro and the correct drivers (I speak in general).
    Desktop PC
    3 Heads Digital Films
