Latest post Sat, Jan 5 2019 11:28 AM by DIESELE. 7 replies.
  • Fri, Dec 21 2018 10:24 AM
    • DIESELE
    • Joined on Mon, Apr 28 2008
    • Cymru/Wales
    • Posts 1,062
    • Points 13,100
    Audio stuck in loop in STOP
    Been having this past few days - hit stop and yet audio keeps repeating in a loop over and over again and you have to repeatedly hit stop and play a few more times to get it to shut up.  It loops maybe the last couple of frames of audio.
    Anyone know what it is, what it is, what it is, what it is , what it is?!!!
    Symphony 2018.11, Blackmagic Intensity Pro (cant get it working well in 4k though for client monitor - which was the point...), WIN 10 on 2000Mbps M.2 SSD, Nvidia Quadro K2000, Asus X99 Mobo, 4.0 GHz Hex core CPU, 32Gb 2800 Mhz RAM, WD Black 8Tb RAID10
    VIDEO MEDIA PRODUCTION COMPANY AND FACILITIES CARDIFF, LONDON, BRISTOL, WALES, CRACKING PRODUCTIONS
  • Fri, Dec 21 2018 11:09 AM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 466
    • Points 5,480
    Re: Audio stuck in loop in STOP
    it's your preview card card card.
    i've seen this with aja cards.
    never tried to fix it though.
    MC 8.4.4 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-6, Mojo DX, Artist Color, Flanders CM240, GTX 1070... [view my complete system specs]
  • Fri, Dec 21 2018 11:49 AM In reply to
    • DIESELE
    • Cymru/Wales
    • Posts 1,062
    • Points 13,100
    Reload the driver for the Blackmagic Intensity card maybe? This is what feeds the audio...
  • Fri, Dec 28 2018 7:19 PM In reply to
    We've had this same issue with the DNxIO. It happens when you have your Sound --> Playback set to the hardware and not the Speakers / Headphones of your PC. -- I run into this when I have a browser open that is playing audio (YouTube) while I'm also editing. It happens with the timeline waveform on or off, but mostly when it's on.
    Workaround: When this occurs, quit Media Composer. Switch your Sound Playback from the IO hardware to the Speakers / Headphones. Then switch it back and relaunch Media Composer.
    I hope this helps.
    Marc
    PS - I haven't started a case for this until it becomes a solid issue. Even then, it is pointing to the Blackmagic hardware not necessarily Media Composer.
    Windows 10 Enterprise - Dell Precision 7810 - 32GB RAM - DNxIO - Nvidia Quadro M5000 [view my complete system specs]
  • Fri, Dec 28 2018 7:29 PM In reply to
    • DIESELE
    • Cymru/Wales
    • Posts 1,062
    • Points 13,100
    I have all PC audio routed to the Blackmagic card now (didnt use to do that...) - saves having to switch between sources.
    Since I posted (and despite several reeboots on the day) it hasnt happened since...  ODD!
  • Fri, Dec 28 2018 7:30 PM In reply to
    • Posts 10,018
    • Points 215,715
    Marc - I am starting one as this needs to be addressed
    Thank you for this.....
  • Fri, Dec 28 2018 7:41 PM In reply to
    • Posts 10,018
    • Points 215,715
    D.Evans and marc
    I created a case for each of you...  sounds like a BM issue but I want suppoert on it.  Anyone else see this - please email me directly.
  • Sat, Jan 5 2019 11:28 AM In reply to
    • DIESELE
    • Cymru/Wales
    • Posts 1,062
    • Points 13,100
    Thanks - was happening again today, day, day, day!  Have responded to direct support with info, fo, fo, fo!
