Latest post Thu, Jun 22 2006 9:52 PM by Kevin Klimek. 8 replies.
Page 1 of 1 (9 items)
  • Fri, Jun 16 2006 6:33 PM
    • FMPedit1
    • Joined on Thu, Jun 15 2006
    • Philadelphia
    • Posts 8
    • Points 130
    Clamped video on imported files
    Here is my problem,
    When I export video from my XP Adrenaline 2.2.3 with 6.5.2 Quicktime and then re-import that same file to campare with the original video footage I loaded into the Avid, I see, both on the screen and the video scope, a clamping of the video in the highlights.  It's about 5 IRE.  This happens with .mov(same a source) .mov(custom) and AVI.
    Has this happed to anyone?
    Ed
    HPxw8600 Workstation, Windows7 Professional SP1, Intel Xeon CPU, X5450 @ 3.00GHz (2 processors), 12 GB of installed RAM,64-bit OS, NVDIA Quadro FX 3700... [view my complete system specs]
  • Fri, Jun 16 2006 7:18 PM In reply to
    Re: Clamped video on imported files
    are you exporting RGB or 601?  are you importing RGB or 601?  whatever you use you have to use for both. I would suggest 601 as it doesn't effect the video on import. RBG import will clamp the video down.
    basically 601 levels are from 16-235 on the RGB scale. RGB runs from 0-255. so when you import something that is made with RGB levels, and tell the avid to import with RGB levels, then it squashes the levels down to 16-235.  But if you have something that is 601 (16-235) and then import with RGB setting, then it gets squashed down to about 32-205 or so.
    Follow me at www.twitter.com/redarrowryan Avid 1- z400 6-Core, with Nitris DX Symphony 6.0.3 Win 7 64 Bit [view my complete system specs]
  • Fri, Jun 16 2006 8:04 PM In reply to
    You will especially notice the difference Mr. Difficult describes when you import color bars at first RGB, then 601 (the correct choice) and compare the two.
  • Fri, Jun 16 2006 8:10 PM In reply to
    • FMPedit1
    • Philadelphia
    • Posts 8
    • Points 130
    I am capturing into MC 1:1 RGB and exporting as RGB.  The clamping is only on the highest video level in the frame.  If the scope shows the highlights at 85 IRE on the original media, the imported file will show just the areas of the frame that are in the 85 IRE space clamped to about 80 IRE.  Everything else is unchanged.
  • Fri, Jun 16 2006 8:19 PM In reply to
    Ok, you say you're capturing into MC, not importing so that means your captured material is at 601 (video) color levels, not RGB (graphics) color levels.  Have you tried exporting at 601 levels? If not, do so and then compare.
  • Mon, Jun 19 2006 1:06 PM In reply to
    • FMPedit1
    • Philadelphia
    • Posts 8
    • Points 130
    Yes, I am Capturing at 601.  I did an export at 601, with no luck.
  • Wed, Jun 21 2006 8:49 AM In reply to
    Are you exporting Avid Same as source? Or are you using another codec?
    We have found issues with Animation QTs not translating their color levels properly, but Avid QTs have been OK.
  • Thu, Jun 22 2006 1:29 PM In reply to
    • FMPedit1
    • Philadelphia
    • Posts 8
    • Points 130
    Hi Kevin,
    Yes, I did the same as source, QT reference and an uncompressed .mov and we get the same clamping on the highlights.  We are using the animation codec on the .mov files, so I'll try another setting.
  • Thu, Jun 22 2006 9:52 PM In reply to
    Is you original video level legal?
    When you say its clamping 5 IRE, it's going from what IRE to what IRE?
