Latest post Fri, Apr 12 2019 7:07 PM by Terry Snyder. 6 replies.
Page 1 of 1 (7 items)
  • Sun, Jan 6 2019 11:12 PM
    BCC Page Curl
    Working with the new continuum 2019 and I can't figure out how to apply the page curl.  The old page curl effect was applied across the cut.  Apparently, this new version will only apply to one side or the other, and I need to stack the layers to get it to display the layer below when the page is turned.   I must be missing something?
    MC 2018.4 with Symphony, Matrox MX02 Mini Max, Win 7 Pro, HP Z800 2x6-Core 3.2Ghz Xeon, 48GB ram, Quadro K4200, SanDisk Extreme 240GB SSD as system drive... [view my complete system specs]
  • Mon, Jan 7 2019 1:42 AM In reply to
    Re: BCC Page Curl
    Even more frustrating...   I opened a project that had a BCC page turn effect back from BCC 8.   I tried to drop that same saved effect I've used hundreds of times in the past and it won't drop onto a cut at the transition.
    What I am trying to do is very simple.  I want to drop a page turn between shots to create a photo album effect.   With this new version, it seems you have to stack one shot overlapping the other at the transition.  With a series of page turns in a row, this can lead to multiple layers very quickly.   The old effect was simply dropped on the transition at the cut point.   There must be an easy way to do this but I haven't been able to figure it out.  Embarrassed
  • Fri, Jan 11 2019 5:36 PM In reply to
    Re: BCC Page Curl
    Can anybody point me to a tutorial on how to use the new page curl?   The old one was so easy, but this one is very different.  Thanks.
  • Mon, Jan 21 2019 4:15 PM In reply to
    Re: BCC Page Curl
    Anyone from Boris want to jump in????
  • Wed, Feb 27 2019 10:26 PM In reply to
    Re: BCC Page Curl
    I've been working with the new BCC for a few months now and still can't replicate the old Page Curl effect from BCC8???
  • Fri, Apr 12 2019 1:34 PM In reply to
    • dmfreeman
    • Michigan
    • Posts 1,851
    • Points 24,235
    Re: BCC Page Curl
    Have you tried posting this on the Boris Community forum, they are very helpful there.
    Denny
    Media Composer 8.5.4, BCC 10.0.0074, AvidDVD 6.4.4, Boris Red 5.5.2.1382, Asus P9X79 Pro Motherboard with Intel 3930K Processor. 32 gigs DDR3 ram, Windows... [view my complete system specs]
  • Fri, Apr 12 2019 7:07 PM In reply to
    Re: BCC Page Curl
    dmfreeman:
    Denny
    Thanks, Denny.   I've never been on the Boris Forum.   I'll check it out.
