Latest post Fri, Jan 11 2019 3:52 PM by JPBU. 4 replies.
  • Thu, Jan 10 2019 4:56 PM
    • JPBU
    • Joined on Sat, Jan 11 2014
    • Canada
    • Posts 135
    • Points 1,830
    Multigroup from a sequence
    I there a tutorial or official documentarion for the new "create multigroup from a sequence" in 2018.12 ?
    Media Composer 2018.10 | iMac Pro (2017) 3.2 GHz Intel Xeon W | 64 GB 2666 MHz DDR4 | Radeon Pro Vega 56 8176 MB | G-Raid 16TB Thunderbolt 3 | macOS... [view my complete system specs]
  • Thu, Jan 10 2019 11:35 PM In reply to
    Re: Multigroup from a sequence
    JPBU:
    The docs for this release do have good instructions, notes. Did you see them? PVC’s Scott Simmons has a web thing coming up soon.
  • Fri, Jan 11 2019 2:13 PM In reply to
    • JPBU
    • Canada
    • Posts 135
    • Points 1,830
    Great thank you I found it:
    Creating a group clip from a sequence:
    1. Load the sequence in the Timeline.
    2. Right click in the Record Monitor and choose Create Group.
      A group is created and added to your bin.
      Currently, you must have one audio track from a clip to include any audio from that clip in the group.
    Additional Changes to Group Clips
    Note the following changes you will see when working with group clips:
    • You can add mixed rate clips to a group clip.
    • When you are segment dragging in Group mode, you will notice the monitor displays the frame under the blue bar.
    • Known issue with beta build: Mixed rate groups may cause errors during Commit Multicam Edits
    • Groups from any project type can be opened in any other project (no longer need matching edit rates)
    • Sequences can be modified to any project type without Commit Multicam Edits.
  • Fri, Jan 11 2019 3:23 PM In reply to
    It is wonderful. Including the ability to modify.
    *Take note of what happens to certain segment FX on clips as your Sequence copies to a MultiGroup and then comes back onto a timeline.
  • Fri, Jan 11 2019 3:52 PM In reply to
    • JPBU
    • Canada
    • Posts 135
    • Points 1,830
    Indeed! This is probably the best new feature in a long time for my type of work.
    The new Titler would have been the second if only it was... Well, if it was usable.
