Latest post Sat, Jan 26 2019 9:32 PM by Matthew Clulow. 3 replies.
  • Thu, Jan 24 2019 9:19 PM
    • Matthew Clulow
    • Joined on Mon, Feb 12 2018
    • North of Toronto Ontario
    • Posts 30
    • Points 360
    Shape Based Colour Correction
    Just bought NEWMC - stepping up from version 4.8
    I saw in the advertising that MC can do shape based colour correction. Can you point to to the starting point for this. I looked in the filter bin and don't see anything obvious.
    Thx
    Windows 10 Pro Version: 1709 OS Build 16299.192INtel Core(TM) i5-2400 CPU @3.10Ghz 310 GHz8GB Ram - 7.88 usable64 bit x64 based processorDell Optiplex... [view my complete system specs]
    Matthew Clulow
  • Thu, Jan 24 2019 9:46 PM In reply to
    Re: Shape Based Colour Correction
    Not really a SBCC video tutorial but it takes you to where you need to start.
    https://www.youtube.com/watch?v=ZXfv9XFyTIg
    AVID MEDIA COMPOSER 5.5.3. PC. WINDOWS 7, SP1. 64BIT OPERATING SYSTEM. QUICK TIME VERSION 7.6.9. [view my complete system specs]
    Christian Jhonson
    Avid Ambassador
    christianjhonsoon@hotmail.com
  • Fri, Jan 25 2019 4:35 PM In reply to
    • Joachim Claus
    • Seeheim-Jugenheim, Germany
    • Posts 918
    • Points 11,745
    Hi Matthew,
    shape based Color Correction is only available in MC if you have actvated the Smphony Option, i.e., you must have a license key for Symphony. If activated, it is available in the normal color correction moce. If you enter into CC-mode, you will see a slightly modified ui with some more setting parameters.
    See the enclosed screenshot.
    Joachim
    Joachim Claus
  • Sat, Jan 26 2019 9:32 PM In reply to
    • Matthew Clulow
    • Posts 30
    • Points 360
    Thanks Joachim Claus.  Thats very helpful. I'll have a look at that
    Matthew Clulow
