Latest post Wed, Jan 30 2019 3:56 PM by Supermandan1. 8 replies.
Page 1 of 1 (9 items)
  • Sun, Jan 27 2019 10:39 PM
    Audio there, but blank video on import
    I'm attempting to import MOV files into MC.  While they play perfectly well in ordinary media players, and even AMA link well enough, the files do not play video (just a blank screen) when importing.  This has never happened before.
    Please advise,
    DC
    Asus N55SF Notebook running Windows 10 Home Processor: Intel(R) Core (TM) i7-2670QM CPU @ 2.20GHz 2.20GHz Installed memory (RAM): 8.00 GB System type... [view my complete system specs]
  • Mon, Jan 28 2019 6:10 AM In reply to
    Re: Audio there, but blank video on import
    If they link ok, then just link them and transcode them to whatever resolution you like. You'll wind up with the same result as if you'd imported them, and transcoding is usually faster than importing.
  • Mon, Jan 28 2019 2:49 PM In reply to
    • Tom Pearson
    • Joined on Thu, Mar 1 2007
    • Los Angeles CA / Minneapolis MN
    • Posts 2,156
    • Points 23,150
    also if you are on windows it might be a quick time thing as it is no longer supported in windows so as Carl said ama them and transcode them
    Mac Pro 3.5 gig 6 core 64 gig ram D700 radons with ssd os drive with a 20 tb raid, Artist Mix and Artist color Artist control [view my complete system specs]
    Tom Pearson
  • Mon, Jan 28 2019 8:19 PM In reply to
    Strange that it should work one way but not the other.  So what are the full differences between importing and transcoding?  And how does QT no longer supported by Windows make a difference?  (Also, I still have a QT player on my system and checked that, and it works.)
  • Mon, Jan 28 2019 9:18 PM In reply to
    Supermandan1:
    They are two different ways of arriving at the same result. Importing creates media directly during the import process, and link & transcode creates media during the transcode part of the process. The media created each way is the same.
  • Tue, Jan 29 2019 2:26 PM In reply to
    Thank you.  Two things: what does QT no longer supported on Windows mean, and how this might affect me working in MC? And I'm not there just yet, but will be soon, is this likely to affect a time lapse import (sequential JPEGS, a process I've done a lot)? I guess I will find out soon enough, though just trying to act prepared.
  • Wed, Jan 30 2019 3:41 PM In reply to
    Hi there, can someone please take a look at the above query.  Thank you, D.
  • Wed, Jan 30 2019 3:50 PM In reply to
    Quicktime 7 has been EOL’d by Apple a long time ago, but classic file-import in MC was built on using the QT engine to being certain types of media in.
    AMA/Linking is a much more modern way to bring in source video files. While it CAN use QT for certain file types, it has dedicated engines for many codecs and containers.
    In general, for importing video files, linking&transcoding is more versatile and much faster than any traditional File-Import.
    I’m not sure if sequential JPEG uses the QT engine, but I think Linking to an image sequence is also possible.
  • Wed, Jan 30 2019 3:56 PM In reply to
    Ok, thank you.  So the technical answer is that transcoding is faster than importing because, while it may end up as the same 'destination' (ie., an MXF file), it could well be a different codec that gets you there?
