Latest post Thu, Feb 14 2019 9:14 AM by Bruno M. 1 replies.
Page 1 of 1 (2 items)
  • Thu, Feb 14 2019 4:52 AM
    • cls105
    • los angeles
    • Posts 403
    • Points 5,195
    Major Multicam bug in 2018.12.1
    Groups that have mixed rate clips in them (created on a timeline/the new feature) can be very problematic when attemping to commit multicam edits.
    I keep getting: range specified for dup is outside range of component
    and "tracks have incompatible edit rates"
    I am manually match framing my non native fps clips and overwriting since commiting doesnt work.
    MC 2018.12.1, diy x299 7940x 4.5ghz OC, 1080ti, 128gb ram, w10 pro (1803) DM me on instagram for tech Q's: dvhaime [view my complete system specs]
  • Thu, Feb 14 2019 9:14 AM In reply to
    • Bruno M
    • Joined on Thu, Feb 11 2010
    • London, UK
    • Posts 551
    • Points 7,035
    Re: Major Multicam bug in 2018.12.1
    Have you tried going into the Source Settings and changing the frame rate settings for those clips?
    You can access this from the 'Playback Rates' tab. Normally, you'll get two options - clip rate and project rate. You could try flipping the setting and seeing if this allows you to commit the edits.I think this only works if you've linked to the clips. Once you've transcoded/imported clips, the framerate will be baked in.
    Flipping the frame rate like this (if it's even possible within a multicam group) might also cause sync issues because of the different frame rate.
    HP Z800, HP G3 Studio, SonnetFusion RAID, Mojo DX, Symphony 2018.9, JVC DTV1910 HD tube monitor, HP Dreamcolor, Avid Artist Color [view my complete system specs]
