Latest post Fri, Feb 15 2019 8:30 PM by knollcrest. 2 replies.
  • Fri, Feb 15 2019 4:28 AM
    Importing Audio from Sound Devices 633
    Is there a shortcut to importing audio from the Sound Devices 633 folder structure?
    Instead of being able to import files from a whole day, it seems I have to click into each scene/set-up one by one.
    (a) This is annoying. (b) I fear I'm losing metadata? .... Any tips???
    AS WELL — audio file names all come into Avid with slashes — then I have to go through and change to underscores. This seems preposterous... someone out there must know a workaround?? THANKS ALL !!!
  • Fri, Feb 15 2019 7:06 AM In reply to
    Re: Importing Audio from Sound Devices 633
    Can't you just do an OS search for ".WAV" for that day folder and drag the results into MC?
    The slashes versus scores is a matter of how the SD633 writes the name in its metadata.
    You might be able to change this by first importing the WAV files, then exporting the bin as an ALE, then batch replace slashes with underscores in a text editor, then import/merge the ALE back into MC.
    But why underscores? Pretty much all sound recorders I have encountered write the clip name as XYZ/ABC/TN.
  • Fri, Feb 15 2019 8:30 PM In reply to
    Gotcha, thank you. Okay I'll post again if I have any trouble down the line.
