Latest post Tue, Feb 19 2019 12:23 PM by BarkinMadd. 21 replies.
Page 2 of 2 (22 items) < Previous 1 2
  • Mon, Feb 18 2019 3:28 PM In reply to
    • Matthew Clulow
    • Joined on Mon, Feb 12 2018
    • North of Toronto Ontario
    • Posts 30
    • Points 360
    Re: Colour Grading Tool - Looking for options
    Tried installing the free DaVinci app and it wont start...web indicates it's a common problem.
    Windows 10 Pro Version: 1709 OS Build 16299.192INtel Core(TM) i5-2400 CPU @3.10Ghz 310 GHz8GB Ram - 7.88 usable64 bit x64 based processorDell Optiplex... [view my complete system specs]
    Matthew Clulow
  • Mon, Feb 18 2019 3:35 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,627
    • Points 60,455
    Martin Fox:
    i thought of the baselight plug in but couldn’t see how you could simultaneously refer to an adjacent shot while grading,
    (I didn’t try it).
    Hi Martin,
    After I posted this same question, below, I had a look at the most recent tutorial for Baselight 5.1 on the Filmlight website and they do describe the use of the scratchpad to capture the equivalent of power windows in Resolve and then you can wipe between the current shot and one of the scratchpad slots to perform shot matching (you can even use the new base grade to perform a preliminary color match between the reference (scratchpad image) and the current segment).
    It would be worth creating a tutorial to demonstrate this workflow as it is something that was not readily available in Baselight 4.4 and is one of several new features to that the Baselight integration to the next level.
    Not sure if I will have time but if I do, I'll post a link back to this thread.
    Camera(s) PXW-X70, HDR-FX1, Hero 6 Black | MC 18.12.1 | QT 7.7.9 | Continuum 2019 | Sapphire 2019 | Mocha Pro 2019 | Titler Pro 6 | Windows 10 Pro x64... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Mon, Feb 18 2019 3:38 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,627
    • Points 60,455
    Matthew Clulow:
    Resolve is a power-hungery application. It typically requires a top-end GPU such as an nVidia 1080 TI or a P4000 (usually a pair of these, actually). Mileage may vary and some have had success with lesser machines.
    Steve
  • Mon, Feb 18 2019 5:53 PM In reply to
    • Bruno M
    • Joined on Thu, Feb 11 2010
    • London, UK
    • Posts 576
    • Points 7,370
    Matthew Clulow:
    Looking at your specs, it looks like you're using an onboard Intel Graphics chip, which may be the problem.
    Resolve will work reasonably well with a modest Nvidia card. If you don't want to splash out on a new card then something like a second-hand Quadro 4200 should work.
    HP Z800, HP G3 Studio, SonnetFusion RAID, Mojo DX, Symphony 2018.9, JVC DTV1910 HD tube monitor, HP Dreamcolor, Avid Artist Color [view my complete system specs]
  • Mon, Feb 18 2019 6:57 PM In reply to
    • damien78
    • Joined on Tue, Jan 7 2014
    • Geneva
    • Posts 27
    • Points 315
    In Baselight for Avid, unfortunately, wipe is available only on UI display, and not on the video output/reference monitor.
    I contacted Baselight support which had confirmed that limitation.
    My question: "I'm trying to use scratchpad to match different shots. I managed to do that on my GUI display, but I didn't find any solution to have a WIPE view or a side-by-side view displayed on my reference display. Is it actually possible?"
    Support answer: "This isn’t possible - the wipe is only shown on the UI display.
    Media Composer 2018.12.1, w/Symphony/SS/PF options, MAC PRO 2013 3.5 GHz 6-Core Intel Xeon E5, ATI FirePro D500 3072 Mo, 32 GB RAM, MacOS 10.13.6, AJA... [view my complete system specs]
  • Mon, Feb 18 2019 11:16 PM In reply to
    • Martin Fox
    • Joined on Fri, Mar 14 2014
    • Sydney Australia
    • Posts 224
    • Points 2,380
    damien78:
    Thanks for the explanation, it’s a pity as the UI is not a good enough reference, perhaps with use one can get a feel for it.
    Regarding the resolve app, the App Store version is limited in some way compared to the free download from the BMD website, perhaps someone could clarify the differences.
  • Tue, Feb 19 2019 12:23 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,627
    • Points 60,455
    Martin Fox:
    I agree but the reference wipe on the UI IS probably good enough for shot matching...
    Martin Fox:
    I have heard this as well but I can't recall the difference - Why not buy the studio version from a retailer such as BandH? (BTW - if you don't mind using a dongle, if you buy the studio version of Fusion, it will also enable the studio version of Resolve)
    Steve
