Latest post Wed, Feb 20 2019 6:08 AM by Telegram!. 9 replies.
Page 1 of 1 (10 items)
  • Tue, Feb 19 2019 10:41 AM
    • Kevs999
    • Joined on Mon, Jul 18 2016
    • Posts 36
    • Points 455
    Relinking to new media with extra audio tracks
    Hi
    I have edited some sequences with a .mov file with 2 audio tracks.
    Now I have been sent the same files in a different format (.mxf) with extra audio tracks (all in a single file with the video) which contain sound I will need.
    The first 2 audio tracks match the original file as does the timecode and durations.
    I can't find a way to let the sequences relink to this new media, is it possible if the new file now has 16 audio tracks compared to the original file which only had 2 ?
    I have tried renaming the new files so they are identical to the originals but no joy.
    Any thoughts would be appreciated.
    HP Z420 Windows 10 Professional 64 bit 8GB RAM Dual Zeon Processor E5 1650 Nvidia Quadro K2000 [view my complete system specs]
  • Tue, Feb 19 2019 12:59 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,627
    • Points 60,455
    Re: Relinking to new media with extra audio tracks
    I gave this a try and relinked by file name (ignoring extension) and it worked but it did not link to the additional audio tracks. I used the relink method where you relink to selected media in open bins (so I created two bins - one with the MOV files and one with the MXF files and I just selected the MXF files and the sequence and then performed the relink).
    The only way I could then get the additional audio tracks on the timeline was to locate the (now relinked source) for each clip in the relinked sequence and replace it with the new source. Very tedious. Hopefully someone else will have a better answer for you.
    Camera(s) PXW-X70, HDR-FX1, Hero 6 Black | MC 18.12.1 | QT 7.7.9 | Continuum 2019 | Sapphire 2019 | Mocha Pro 2019 | Titler Pro 6 | Windows 10 Pro x64... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Tue, Feb 19 2019 1:26 PM In reply to
    • Kevs999
    • Posts 36
    • Points 455
    Thank you for your reply.
    I tried that method but still didn't get as far as you. Copied the file name from the original and pasted to the new so they are identical apart from file extension.
    Told relink to link to different target and use file name and ignore extension etc but still not able to link at all.
    I did put the new file in a new bin as well ?
  • Tue, Feb 19 2019 1:48 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,627
    • Points 60,455
    What relinking method did you use? Did you use the 'Selected items in all open bins...' option? I'm assuming all media is linked via AMA, correct?
    Sorry I can't be of any help here. Hopefully someone else will chime in...
    Steve
  • Tue, Feb 19 2019 5:12 PM In reply to
    • Kevs999
    • Posts 36
    • Points 455
    Yes all AMA linked and ticked Selected Items in open bins.
  • Tue, Feb 19 2019 6:17 PM In reply to
    BarkinMadd:
    IF you Clip/Modified the original 2-audio mov clip to add the same number of audio tracks on the new .mxf, would it then Relink, I wonder?
  • Tue, Feb 19 2019 6:59 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,627
    • Points 60,455
    That's an interesting idea... I'll give it a try.
    edit - Yes it worked but it probably doesn't help the OP because the editing was already performed (there would be quite a bit of manual effort, I suppose).
    Steve
  • Tue, Feb 19 2019 8:50 PM In reply to
    BarkinMadd:
    good to know...
    now OP should be able to jump from edit to edit, hitting matchrame, to access tracks above 1&2 loaded in SRC monitor.
  • Wed, Feb 20 2019 1:15 AM In reply to
    • cls105
    • los angeles
    • Posts 432
    • Points 5,610
    I've said this before but avid should really allow manual relinking to files.
    The relink method is a mess.  Somtimes one just wants to SIMPLY point media composer to the correct files.
    MC 2018.12.1, diy x299 7940x 4.7ghz OC, 1080ti, 128gb ram, w10 pro (1803) DM me on instagram for tech Q's: dvhaime [view my complete system specs]
  • Wed, Feb 20 2019 6:08 AM In reply to
    cls105:
    I saw you asked for manual Relink here:
    http://community.avid.com/forums/t/196459.asp
    I’m just wondering, did you ever try copy/pasting the original mixdown’s (randomly-generated alpha numeric).mxf file name?
    Maybe that would have worked? And yes, we all like simple solutions...
