Latest post Sat, Mar 2 2019 12:39 AM by Marianna. 1 replies.
Page 1 of 1 (2 items)
  • Sat, Mar 2 2019 12:01 AM
    • asveprod56
    • Joined on Tue, May 17 2011
    • Posts 1
    • Points 15
    Avid Media Composer Crashing when trying to update or reinstalling
    When trying to reinstall or update MC it loads the software needed until and included of Pace 3.1.3. then the Windows Installer crashes. I tried to de- install and re-install MC 2018.9 because Updating to 2018.12 didnt work and old Titles coudnt be modified, only new ones created. Now I cant even re-install the old version 2018.9. The Avid Support forms are very compicated and misguiding to even send a request. this seems to be the only place possible for MC support request. I do use a USB dongle since I sometimes have to edit projects on amac besides windows, but never at the same time. With 2018.9 it worked until yesterday, but not after reinstalling.
    Windows ® Installer. V 5.0.17134.228
    msiexec /Option <Required Parameter> [Optional Parameter]
    Install Options
        </package | /i> <Product.msi>
            Installs or configures a product
        /a <Product.msi>
            Administrative install - Installs a product on the network
        /j<u|m> <Product.msi> [/t <Transform List>] [/g <Language ID>]
            Advertises a product - m to all users, u to current user
        </uninstall | /x> <Product.msi | ProductCode>
            Uninstalls the product
    Display Options
        /quiet
            Quiet mode, no user interaction
        /passive
            Unattended mode - progress bar only
        /q[n|b|r|f]
            Sets user interface level
            n - No UI
            b - Basic UI
            r - Reduced UI
            f - Full UI (default)
        /help
            Help information
    Restart Options
        /norestart
            Do not restart after the installation is complete
        /promptrestart
            Prompts the user for restart if necessary
        /forcerestart
            Always restart the computer after installation
    Logging Options
        /l[i|w|e|a|r|u|c|m|o|p|v|x|+|!|*] <LogFile>
            i - Status messages
            w - Nonfatal warnings
            e - All error messages
            a - Start-up of actions
            r - Action-specific records
            u - User requests
            c - Initial UI parameters
            m - Out-of-memory or fatal exit information
            o - Out-of-disk-space messages
            p - Terminal properties
            v - Verbose output
            x - Extra debugging information
            + - Append to existing log file
            ! - Flush each line to the log
            * - Log all information, except for v and x options
        /log <LogFile>
            Equivalent of /l* <LogFile>
    Update Options
        /update <Update1.msp>[;Update2.msp]
            Applies update(s)
        /uninstall <PatchCodeGuid>[;Update2.msp] /package <Product.msi | ProductCode>
            Remove update(s) for a product
    Repair Options
        /f[p|e|c|m|s|o|d|a|u|v] <Product.msi | ProductCode>
            Repairs a product
            p - only if file is missing
            o - if file is missing or an older version is installed (default)
            e - if file is missing or an equal or older version is installed
            d - if file is missing or a different version is installed
            c - if file is missing or checksum does not match the calculated value
            a - forces all files to be reinstalled
            u - all required user-specific registry entries (default)
            m - all required computer-specific registry entries (default)
            s - all existing shortcuts (default)
            v - runs from source and recaches local package
    Setting Public Properties
        [PROPERTY=PropertyValue]
    Consult the Windows ® Installer SDK for additional documentation on the
    command line syntax.
    Copyright © Microsoft Corporation. All rights reserved.
    Portions of this software are based in part on the work of the Independent JPEG Group.
  • Sat, Mar 2 2019 12:39 AM In reply to
    • Posts 10,159
    • Points 217,400
    Re: Avid Media Composer Crashing when trying to update or reinstalling
    Hey there
    Created a case for you ( # 03662065) and support will reach out.
