Latest post Wed, Mar 13 2019 2:33 PM by secondwindcreative. 2 replies.
  • Tue, Mar 12 2019 9:54 PM
    Problem with PhraseFind and Indexing
    I am new to AMC and have been given a project from another editor. I will be making selects and rough outlines then delivering back to the lead editor.
    I first installed 2018.12.1, but was informed that PhraseFind is broken and i would need to roll back to 2018.12. I did that and PhraseFind is now activated, BUT I am have a problem where it will not index the files. I contacted support and they gave me several solutions to try -
    - Delete SearchData Folder and reopen, stop indexing, restart indexing,
    - Create a new project, copy over bins and try from there
    No luck so far.
    I have somehow managed to get it to index one interview. There are two .pat files in the PhoeneticData folder. Another note.. the one interview that does show results in PhraseFind was one I shot last week and imported. Does anyone know any solutions to Index the entire project so I can begin using PhraseFind from every interview?
    p.p1 {margin: 0.0px 0.0px 2.0px 6.0px; line-height: 20.0px; font: 12.0px 'Helvetica Neue'; color: #000000; color: rgba(0, 0, 0, 0.85)}
    [Case : 03666384]
  • Wed, Mar 13 2019 2:33 PM In reply to
    Re: Problem with PhraseFind and Indexing
    Example, I can get it to index this one interview for some reason, but not the rest of the project. I have opened other bins and interviews. Nothing happening. The PhraseFind Index stays half green.
  • Wed, Mar 13 2019 3:01 PM In reply to
    • Posts 10,152
    • Points 217,280
    Are there by chance - Sequences in the project?  Why is ask is that PhraseFind PhraseFind does not index and return Sequences at this time.
    PhraseFind indexes any bin with online media, including AMA bins, shared bins, or bins that show up under the Other Bins list.
    What I would do is this......
    In the Project folder, you have a folder called SearchData which contains a file called _SearchDB_.
    This file is the database created by Find when it indexes the bins of your project. If you have PhraseFind installed, you will also see a folder called PhoneticData which contains a number of files with a .pat extension; these files contain the phonetic information for each of the audio clips within your project.  One .pat file will be created per clip.
    I would delete the SearchData and PhoneticData folders from your Project folder that is suspect. Note that you can only delete these folders  when your editing application is not running.
    The next time you launch your editing application, Find will then re-index all of the bins within your project.
    Report back.
