Latest post Thu, Apr 18 2019 6:44 PM by DIESELE. 9 replies.
Page 1 of 1 (10 items)
  • Wed, Mar 13 2019 11:07 AM
    • DIESELE
    • Joined on Mon, Apr 28 2008
    • Cymru/Wales
    • Posts 1,096
    • Points 13,465
    Sub Cap - row spacing issue - any tips?
    My captions have inconsistent row spacing - seems dependent on how many 'tails' from the top row and if there are any caps in the bottom row.  If its yes to both then you get a big gap and a small gap if not:
    BIG
    SMALL
    It looks ugly as its inconsistent and the box size jumps between cuts.  Does anyone know a workaround?
    Have had a good fiddle inc padding and 'row spacing' - they are just global adjustments though and the unpredictability in spacing continues. Happens without the box too.
    Cheers
    Symphony 2018.12.3, Blackmagic Intensity Pro 11.1 (unsatisfactory in full res UHD though for client monitor), WIN 10 on 2500Mbps M.2 SSD, Nvidia Quadro K2000 (rolled back 388.16 driver to see if matches old but adequate card better), Asus X99 Mobo, 4.0 GHz Hex core mildly overclocked CPU, 32Gb 2800 Mhz RAM, WD Black 8Tb RAID10 @ 450Mbs
    VIDEO MEDIA PRODUCTION COMPANY AND FACILITIES CARDIFF, LONDON, BRISTOL, WALES, CRACKING PRODUCTIONS
  • Wed, Mar 13 2019 12:21 PM In reply to
    Re: Sub Cap - row spacing issue - any tips?
    DIESELE:
    Just to be sure you should double-check row spacing. If you click on the Edit Global Properties button in the Effect Editor, then look at Box Appearance > Row Spacing and make sure it is set to Sequence if you want the spacing to be the same on all the SubCap effects in the sequence.
    FWIW, mine was set to Clip by default, which would account for the differences you're seeing if yours is the same.
    Media Composer 2018.12.5 w/Symphony/SS/PF options, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce... [view my complete system specs]
  • Wed, Mar 13 2019 1:14 PM In reply to
    • DIESELE
    • Cymru/Wales
    • Posts 1,096
    • Points 13,465
    Thanks Carl.  Reviewed that all and I'm afraid it didnt help.  I then loaded a known good preset I used for a 50 min HD prog, resized it down to this custom project size of 512 x212 and again it started behaving inconsistently - this time big gap between certain text and lower edge of box - dependent on text.
    Frustrating but think I'm stuck with this as a feature in a non native project size.  Its fine in HD. Thanks for trying to help.
  • Wed, Mar 13 2019 3:04 PM In reply to
    • Posts 10,284
    • Points 219,195
    dev
    Let me look at this and ask support to check as well.  what font are you using?      Created a case for you...  Case # 03668871
  • Wed, Mar 13 2019 3:50 PM In reply to
    • DIESELE
    • Cymru/Wales
    • Posts 1,096
    • Points 13,465
    Thanks M.  Just using the Arial font.
    I'm using this odd 512X288 project size as its videos for an app.
    These are my settings:
  • Wed, Mar 13 2019 5:24 PM In reply to
    • Posts 10,284
    • Points 219,195
    Excellent.... added this to the case and now to try it alongside support to see if we both get the same result
  • Wed, Mar 13 2019 6:06 PM In reply to
    • Sharney A
    • Joined on Tue, Aug 16 2016
    • Devon, UK
    • Posts 11
    • Points 175
    Hi
    We are running on Macs and have come across the same problem, doesn’t matter what the global properties are.  Our presets as well as new ones behave the same way.
    MacPro 3GHz 8 Core Intel Zeon E5, 64GB Ram, Dual D700 6GB, Avid Artist DNxIO, Avid Media Composer V1018.11 with Symphony Option, Boris V10, Sapphire V10... [view my complete system specs]
  • Wed, Mar 13 2019 6:20 PM In reply to
    • Posts 10,284
    • Points 219,195
    Sharney
    I created a case for you as well...   03669040
    Could you ping me with your system ID please.
  • Thu, Apr 18 2019 7:33 AM In reply to
    • Jonas
    • Joined on Thu, Jul 12 2018
    • Stockholm
    • Posts 4
    • Points 60
    Hi
    Was this problem ever solved?
    Unfortunately it seems like I have the same issue.
    Jonas
  • Thu, Apr 18 2019 6:44 PM In reply to
    • DIESELE
    • Cymru/Wales
    • Posts 1,096
    • Points 13,465
    Its far better in the current version - row spacing is much more consistent.  Caps or 'long tail' characters dont cause inconsistent row spacing.  Been a while coming mind ;)
