Latest post Wed, Apr 3 2019 2:26 PM by luca.mg. 35 replies.
Page 1 of 3 (36 items) 1 2 3 Next >
  • Tue, Mar 19 2019 8:07 PM
    Media Composer 2018.12.2 Available Now 19 Mar 2019
    Media Composer 2018.12.2 - Launched Today 3.19.19
    Avid is pleased to announce the December release of Media Composer 2018.12.2, which is available today, Tuesday March 19th, 2019.
    Location at Launch:  This update to 2018.12.2 is available from MyAvid Master Accounts, Avid Link, and the Avid Download Center (login and password required).
    Media Composer Notes:  Listed below are a few hot items that customers need to be aware of.  Please check the ReadMe for additional notes relating to Media Composer 2018.12.2.
    -  Avid Artist DNxIO and Avid Artist DNxIQ: If you are using Avid Artist DNxIO, Avid Artist DNxIQ, or a BlackMagic Designs video device, please update to Desktop Video software version 10.10.1 or higher. The minimum Desktop Video version that will work with Media Composer v18.5.1 is 10.9.11. Older versions will be rejected, and you will not be able to use your hardware until you update.
    -  When installing the Sentinel Driver:  check your System Preferences and select “Security and Privacy.” You may need to choose to Allow the driver to be accessed.
    - NVIDIA Driver: The editing application supports Nvidia Driver v390.77.
    - DX Driver installed separately: Starting with Media Composer v8.9.4, the DX Driver was not automatically installed on Mac systems. With this release, the DX Driver is not automatically installed on Windows systems. See Avid DX Driver Separate Installer.
    Additions to Media Composer 2018.12.2:  The following additions have been made for this release.
    -  Avid Titler Update:  In previous releases, you could animate only one text layer, and no shapes. With this release, you can animate up to a total of 10 layers (any combination of text and/or shapes).
    -  Multiple Groups: With this release, you now can select the clips, right click and select Multigroup.  Enable Multiple Groups. When this is checked, multiple groups are created instead of a Multigroup clip.
    -  New DNX Uncompressed Format - S2.14:  This release supports DNxUncompressed S2.14.
                • For YCbCr projects: DNxUncompressed 4:2:2 16 (2.14) bit MXF
                • For RGB projects: DNxUncompressed RGB 16 (2.14) bit MXF
    Fixed in Media Composer 2018.12.2:   The following have been fixed:
    -  Bug Number: MCCET-2825. An AAF embedded export from Media Composer did not import properly into Pro Tools v12.7.1 and earlier. If you experience this problem, enable the “ProTools 10/12 compatibility” option in the Export as AAF dialog. The exported AAF will be compatible with earlier versions of Pro Tools.
    -  Bug Number: MCDEV-10448. (Avid Titler+) In some instances, selecting active windows did not work properly if you were working with an Input Method Editor (IME).
    -  Bug Number: MCDEV-10384. (Avid Titler+) Unrelated buttons inadvertently appeared in the Effect Editor when working with an Avid Titler+ effect. The buttons have been removed.
    -  Bug Number: MCDEV-10383. (Avid Titler+) Changing the font or color, or editing your text in your animated title would break the animation.
    -  Bug Numbers: MCCET-2804, MCDEV-10291. You could not enter Japanese text when working with the Avid Titler+.
    -  Bug Number: MCCET-2835. When working with MetaGlue media, you might have received an exception error when Media Composer tried to build the database for 16mm media, and 35mm 3 perf media.
    -  Bug Number: MCCET-2837. Dynamic Relink settings were not retained in shared projects when saved as a site setting.
    -  Bug Number: MCCET-2867. In some instances, frames were mixed up after rendering some effects on linked H.264 media.
    -  Bug Number: MCCET-2851. The editing application crashed when selecting multiple audio keyframes using Alt+Shift+drag.
    -  Bug Number: MCCET-2463. Intermittently, AMALogger files incorrectly appeared in the User folder.
    -  Bug Number: MCCET-2813. In Media Composer versions after v2018.5, when capturing from a deck, you might have received a “Communication error had occurred” error.
    -  Bug Number: MCCET-2808. The editing application would hang if you performed a search in the Marker window, followed by changing the camera angle on a Multigroup clip.
    -  Bug Number: MCCET-2659. The Timecode Burn-In effect did not accurately display the sequence name if the sequence had filler at the start.
    -  Bug Number: MCCET-2788. Exporting XDCAM media with Mono audio enabled resulted in an exception error.
    -  Bug Number: MCCET-2519. In some instances, depending upon the font and size, Subcap titles were cut off.
    -  Bug Number: MCCET-2774. The Source setting, Auto function was not working properly for Canon C-Log color transformation.
    -  Bug Number: MCCET-2503. In some instances, effect parameters were not updated when rendering a Timecode effect.
    -  Bug Number: MCCET-2814. (Windows) On some systems, you could not mute or adjust the volume using the Monitor Volume button.
    -  Bug Number: MCCET-2766. If the Movement During Play is set to Page in the Timeline Settings, and Clip Frames are enabled in the Timeline, the Timeline page movement does not work properly.
    -  Bug Number: MCCET-2765. Some uppercase characters in the Hungarian alphabet were cut off in the Subcap effect.
    -  Bug Number: MCCET-2840.  Effects added to video on V1 were actually added to filler on V2.
    -  Bug Number: MCCET-2829. (Interplay) The “Root Folder for this Project” value was not always maintained in the Production Management Folder Settings dialog.
    -  Bug Number: MCCET-2838. Timeline Views mapped from the Command Palette were not retained after you restarted the editing application.
    -  Bug Number: MCCET-2842. You might not have heard audio when linking and importing .MTS files.
    -  Bug Number: MCCET-2826. (Mac) Language options were not available for PhraseFind and ScriptSync.
     Bug Number: MCCET-2784. In some instances, the blue Position Indicator would hang or disappear during playback if you zoomed in on the Timeline.
    -  Bug Number: MCCET-2603. The Dyn3 Compressor Limiter (Side Chain) Audio Track Effect was not working when activated
    -  Bug Number: MCCET-2795. Languages written from Right-to-Left were not supported in Avid Titler+..
    -  Bug Number: MCCET-2777. In some instances, Avid Media Composer read the timecode incorrectly on native files.
    -  Bug Number: MCCET-2831. Occasionally, playback would stop when it reached certain stereo clips.
    -  Bug Number: MCCET-2761. In some instances, after opening and closing the window, only a small portion of the Deck Configuration window opened and you could not increase the window to normal size.
    Limitations: The following are known limitations (**notice there are much less than before - Great effort Avid Engineering **)
    -  Bug Number: MCDEV-10219. Titles created with Avid Titler+ do not render in the background.
    -  Bug Number: MCDEV-8641. (AMD Graphics). Systems with AMD graphics cards might display tearing when performing Full Screen playback.
    -  Bug Number: MCDEV-9837. (Interplay) If you receive the error “DeleteLocalBinMedia FormatDescriptor is not known” you can only delete the media using Interplay Access.
    -  Bug Number: MCDEV-9460. Windows 7 systems with Nvidia Maxwell or Nvidia Pascal cards might experience playback issues that could result in “Play Consumer timeout” errors. Workaround: Select “Disable GPU Effects” in the Render Settings dialog box.
    -  Bug Number: MCDEV-9142. You might experience hangs or crashes when performing a video
    mixdown with a 16K project on systems with less than 64GB RAM.
    -  Bug Number: MCDEV-9269. (Media Composer | Cloud) After performing a remote download operation on a sequence containing AVC-I 100 remote media, the downloaded media appears as XAVC-I 100. Workaround: Download the entire master clips.
    -  Bug Number: (Mac). You may occasionally see the menu bar flash followed by a brief beach ball. To fix this, deactivate “Displays have separate spaces” under System Preferences > Mission Control settings.
    -  Bug Number: MCDEV-9011. Intermittently, when working with the XDCAM Nablet Plug-in, you might see “Failed to get the sample position from the AMA Plug-in” errors if you have waveforms enabled in the Timeline.
    -  Bug Number: COGS-2560. While working in the Script Window, text operations (cut/copy/paste/delete/editing) can only be done in edit mode. See “Editing a Script” in the Help.
    -  Bug Number: MCDEV-5650. When working with Panasonic LongG media, you might receive an “SFPlayConsumer Timeout” error if audio waveforms are enabled. Workaround: Turn off audio waveforms.
    -  Bug Number: MCDEV-5385. MultiCam editing with Panasonic LongG media is not supported
    with this release.
    -  Bug Number: MCDEV-5384. Currently, when working with LongG media, you might see dropped frames when editing 4 streams. This might occur when playing from a single stream to multiple streams (and from multiple streams back to a single stream). The dropped frames usually display around the edit point (transition to a different stream).
    ReadMe:  Uploaded to the Knowledge Base Media Composer 2018 Documentation Page at launch.
    How to obtain Media Composer 2018.12.2 Updates:
    1.  Customers who have already installed the 2018.18 version of Media Composer will be notified of the availability of the upgrade to 2018.12.2 via Application Manager and Avid Link.  The Apps tab also provides a link to download and install the update when desired.
    2.  Customers on current Update & Support plans can download the Media Composer 2018.12.2 update either from their Avid Master Account or the Avid Download Center (login and password required).
    Media Composer 2018.12.5 w/Symphony/SS/PF options, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce... [view my complete system specs]
  • Tue, Mar 19 2019 8:14 PM In reply to
    Re: Media Composer 2012.12.2 Available Now 19 Mar 2019
    I just found a bug in 2018.12.2 - The Bug number with Avid Tech Support is MCCET-2902. This issue was confirmed.
    **When you do a mixdown inside a nested clip (UHD 29.97), it applies the Resize/Color effect ON TOP of the clips (top level) and bakes it into the layers underneath even when you cannot see it.**
    I already tried different effects and got it to do this with a Color Effect and a Resize effect on different computers. It also happens with any video layer above it, so not just effects, but master clips, as well.
    Workaround: Have NO effect on the top layer of your nested clip (Submaster) and apply any effect AFTER all your mixdowns are done. If you have a clip above, you will need to MUTE that clip while you make your mixdown.
    Marc
    Windows 10 Enterprise - Dell Precision 7810 - 32GB RAM - DNxIO - Nvidia Quadro M5000 [view my complete system specs]
  • Tue, Mar 19 2019 10:36 PM In reply to
    • gorky
    • Joined on Wed, Nov 16 2005
    • Posts 140
    • Points 1,725
    I have another bug.
    Does not work audioscrub with capslock enabled.
    MacBook Pro (Retina, 15-inch, Mid 2014), 2,8 GHz Intel Core i7, NVIDIA GeForce GT 750M 2048 MB, OSX 10.11.6 [view my complete system specs]
  • Tue, Mar 19 2019 10:57 PM In reply to
    • Fazz Powell
    • Joined on Sun, Dec 3 2006
    • Naples, FL
    • Posts 368
    • Points 5,075
    Did the AVCHD AAC bug get fixed? I thought someone said it did, but I don't see it on the list. Thanks.
    MC 2018.10 w/Symphony option. NitrisDX, HP Z800 Dual 2.67Ghz, 500GB SSD, 96GB Ram, Nvidia M4000, BCC2019, Sapphire2019, TitlePro5, ProTools 10.5,Terrablock... [view my complete system specs]
  • Wed, Mar 20 2019 7:39 AM In reply to
    • Lemuriatv
    • Joined on Wed, Mar 5 2008
    • Czech Republic
    • Posts 229
    • Points 2,810
    Fazz Powell:
    Yes, it is listed here:
    EDIT: Just check it and I can confirm that this bug is repaired.
    Intel Core 2 Quad Q6700 2,66 GHz, 8 GB RAM,NVIDIA Quadro K5200, 4 TB for video (2 TB in Raid), Win7ProCZ, MC 7.0.7 DONGLE Matrox MXO2 mini + second system... [view my complete system specs]
  • Wed, Mar 20 2019 12:17 PM In reply to
    • TrevorA
    • Posts 1,148
    • Points 13,005
    Did the bug where using different source tracks of an AMA linked file in the same timeline track (e.g. using source A2 then source A1 as a hard cut on timeiline track 1 results in only source A2 playing, although waveform is correct) get fixed?
    Also, in 2018.12.1 'restore default patch' is greyed out (my timeline has 6 monos and 1 stereo). Anyone else seeing that (I'm on osx high sierra).
  • Wed, Mar 20 2019 12:57 PM In reply to
    • TrevorA
    • Posts 1,148
    • Points 13,005
    Also 'split all tracks to mono' not working on a sequence any more? (comes up with error saying that 'not master clip, subclip or group')
  • Wed, Mar 20 2019 3:07 PM In reply to
    Trevor,
    This is working for me. Check your source settings of the clip.
  • Wed, Mar 20 2019 3:45 PM In reply to
    Praise be, I do believe the Delayed Start on the Pace Licence Service has at last been sorted. Not even a mention in the bug fixes list either.  I will bury my .bat file for modifying the service tomorrow.  R.I.P. little one.  No flowers.
    MC/SN 2018.6+7+8+9+12 x 16 Z400/420/440 PC's on W7 x64. 2 x Mac, 4 x PT 2019.5 HDX, S6 , X-MON, all on PCs. NEXIS E4 & ISIS 5000 X 2. [view my complete system specs]
  • Wed, Mar 20 2019 3:59 PM In reply to
    • Posts 10,284
    • Points 219,185
    Shaden....
    LOL funeral took place a few weeks ago......  Squashed that bugger.
  • Wed, Mar 20 2019 7:23 PM In reply to
    • TrevorA
    • Posts 1,148
    • Points 13,005
    TrevorA:
    Actually it’s tge right click/audio/split tracks to mono that doesn’t work (on timelines). Timeline/Split tracks to mono is fine
  • Wed, Mar 20 2019 9:17 PM In reply to
    • Fazz Powell
    • Naples, FL
    • Posts 368
    • Points 5,075
    So in Application Manger it says 2018.12.2 is available. Is that really 2019.3.1 (March 19th) release? Seems confusing from a version control standpoint based on the naming convention introduced last year. I just wanted to make sure before installing. I'm on 2018.10. Thanks, Dan
  • Wed, Mar 20 2019 9:42 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,627
    • Points 60,455
    Fazz Powell:
    All I can tell you is that 2018.12.2 is the latest Media Composer as of this posting. It represents a large set of bug fixes applied to 2018.12 (released this past December 2018). There have been two such releases in 2019, however, Avid must have seen fit to label these as 2018.12.xxx due to their bug-fix nature.
    Camera(s) PXW-X70, HDR-FX1, Hero 6 Black | MC 18.12.1 | QT 7.7.9 | Continuum 2019 | Sapphire 2019 | Mocha Pro 2019 | Titler Pro 6 | Windows 10 Pro x64... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Wed, Mar 20 2019 9:43 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,627
    • Points 60,455
    I have a question - the notes here say that nVidia driver 390.77 is supported. Has anyone installed the Windows 10 nVidia driver packaged with the 2018.12.2 release? Is it 390.77 or is it 411.95? I'm confused.
    Steve
  • Wed, Mar 20 2019 10:58 PM In reply to
    • Techie Tim
    • Joined on Fri, Aug 29 2014
    • Posts 1
    • Points 5
    I have had a significant problem with intermittant crashes in every format durning export in MC 12, 12.1, 12.2 while MC 11 exports just fine.
    The OS is fine, Windows 10 spinning wheel and Avid MC HardLocks
    • Is the a procedure to follow in upgrades?
    • I tryed deleting MC State, no go
    • Is the an application to give MC a complete clean out for a system
    • Should i get socured earth and reload the entire suite ?
    I can repeat this issue on 3 Different suites, yet 2 other Suites will Export just fine. HPZ420 Windows 10 (Latest) Pro 32gig Ram K2000  Avid DX I/O
