Latest post Thu, Apr 18 2019 5:32 AM by hbrock. 3 replies.
  • Fri, Apr 12 2019 3:37 PM
    • Mike
    • Joined on Wed, Jun 29 2011
    • PA
    • Posts 121
    • Points 1,350
    Removing all Color Correction Effects in a Sequence
    Is there a way to remove all the CC correction on clips in a sequence in using one or few actions? That is without removing any other nested effects.
    Thank you.
    *0SX 10.14.3 *MC Ultimate 2018.12.3 *iMacPro (2017) 2.3 GHz Intel Xeon W-18cor*128 GB 2666 MHz DDR4*Radeon Pro Vega 64X 16 GB *AJA IO4KPlus *AVID ISIS... [view my complete system specs]
  • Fri, Apr 12 2019 8:24 PM In reply to
    • Sharney A
    • Joined on Tue, Aug 16 2016
    • Devon, UK
    • Posts 11
    • Points 175
    Re: Removing all Color Correction Effects in a Sequence
    Hi Mike
    If you have the symphony option it’s a right click in the viewer when inside the colour corrector and ‘Remove Colour Effects’.
    You could try doing the same without the symphony option.
    Sharney
    MacPro 3GHz 8 Core Intel Zeon E5, 64GB Ram, Dual D700 6GB, Avid Artist DNxIO, Avid Media Composer V1018.11 with Symphony Option, Boris V10, Sapphire V10... [view my complete system specs]
  • Tue, Apr 16 2019 11:16 AM In reply to
    • MikeyB
    • Edlesborough, UK
    • Posts 482
    • Points 5,975
    Sadly, Symphony only.
    MacBook Pro 15" 2016 2.7GHz i7 Radeon 455 [view my complete system specs]
  • Thu, Apr 18 2019 5:32 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,520
    • Points 64,055
      Moderator: MCA Mac
    Select segment mode (red arrow), select clips (shift click for multiple clips) with color correction, hit delete (backspace).  This will remove the effect on a clip.  Unfortunately, if there's more than one effect it might not remove the effect you want to remove.
    Otherwise, use the Symphony option.  One right click and they're all gone.
