Latest post Tue, Apr 16 2019 4:17 PM by Victor Wolansky. 16 replies.
  • Mon, Apr 15 2019 6:56 PM
    What to do when a bin opens like this?
    How I fix when the top bar of a bin is behind the the top part of the top bar of the program? You can’t grab it to move it or even close it.
    Thanks.
    HP Z840 Windows 10 Samsun 840 SSD 128 GB Ram GFORCE GTX Titan Black 160 TB DDP over 10GigE [view my complete system specs]
  • Mon, Apr 15 2019 7:08 PM In reply to
    • jdrouette
    • Vancouver, Canada
    • Posts 377
    • Points 4,945
    Re: What to do when a bin opens like this?
    If you select Windows/Close All Bins and re-open the bin, it should pop up in a usuable location.
    Cheers,
    jd
    Avid Media Composer 2018.12.3 Symphony option, Avid Artist DNxID on macOS 10.14.3, iMac Pro (2017) 10-Core, 3.0GHz Intel Xeon W, Turbo Boost up to 4.5GHz... [view my complete system specs]
  • Mon, Apr 15 2019 7:12 PM In reply to
    I did, they still open in the same place.
  • Mon, Apr 15 2019 7:24 PM In reply to
    I don't know that this will work, but it's worth a try:
    1. Click on the bin to make it active
    2. Press CTRL+' (the apostrophe key)
    This is the Home command, and it puts whatever window is active where the system "wants" it to be.
    Media Composer 2018.12.2 w/Symphony/SS/PF options, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce... [view my complete system specs]
  • Mon, Apr 15 2019 7:28 PM In reply to
    I’ll try after it finish the render. I’ll let you know. Thanks.
  • Mon, Apr 15 2019 7:33 PM In reply to
    I forgot which you can delete to reset the last state of your project bins. Anyway...
    Create a new project, preferably with a similar name and move bins or try a different user name
  • Mon, Apr 15 2019 7:39 PM In reply to
    • Fazz Powell
    • Joined on Sun, Dec 3 2006
    • Naples, FL
    • Posts 363
    • Points 5,030
    Can you load one of your saved/default work spaces like edit or audio and then go back to the mode you’re working in?
    MC 2018.10 w/Symphony option. NitrisDX, HP Z800 Dual 2.67Ghz, 500GB SSD, 96GB Ram, Nvidia M4000, BCC2019, Sapphire2019, TitlePro5, ProTools 10.5,Terrablock... [view my complete system specs]
  • Mon, Apr 15 2019 7:44 PM In reply to
    Tried that. The interface changes but bins remain in place.
  • Mon, Apr 15 2019 8:09 PM In reply to
    • Erik
    • Joined on Thu, Oct 5 2006
    • Austin, TX
    • Posts 195
    • Points 2,310
    There is also a command under the Windows tab in the MC top menu called "Center Current". Which will center the currently selected window in the middle of the screen.
    MC 2018.4 Dell Precision 7710 mobile workstation, 64GB of memory, Xeon E3-1535M v5 @2.9Ghz, Nvidia Quadro M5000m. Running Win10 64bit. MC 2018.5 Asus... [view my complete system specs]
  • Mon, Apr 15 2019 8:21 PM In reply to
    It centers it, but the bar to grab it is still hidden.
  • Mon, Apr 15 2019 8:22 PM In reply to
    Tried that, it doesn’t move it at all
  • Mon, Apr 15 2019 8:25 PM In reply to
    • Fazz Powell
    • Naples, FL
    • Posts 363
    • Points 5,030
    Maybe in the new sticky UI-everyone is freaked-out about-this won’t be a problem. Can you wait until then? Yuk yuk. Couldn‘t help myself. Sometimes I drag my entire avid ui up too far and can’t get to anything. I have to log/off log-in to reset it.
  • Mon, Apr 15 2019 9:01 PM In reply to
    Even logging off does not change its place :-(
  • Mon, Apr 15 2019 9:10 PM In reply to
    • jdrouette
    • Vancouver, Canada
    • Posts 377
    • Points 4,945
    Wow, this is pretty crazy.
    If I were you, I would create a new bin in which I would copy everything from the first bin, then delete the old one.
    Hopefully, the new UI will prevent things like this from happening again.
    jd
  • Tue, Apr 16 2019 2:52 PM In reply to
    • knejmann
    • Århus, Denmark
    • Posts 183
    • Points 2,000
    Close the bin by clicking in it and press ctrl+w. Then drag the bin from the project window onto an open bin. This should open the bin as a new tab. Then you can drag the tab away if you want it in its own window.
    Media Composer 2018.12.1 - Windows 10 - Dell 8520 - Blackmagic Decklink Studio 4K - Interplay and NEXIS storage - Avid Artist Color. Plus a lot of HP Z420... [view my complete system specs]
    Kåre Nejmann
    Danish Broadcasting Corporation - DR
    Aarhus, Denmark
