Latest post Thu, Jun 20 2019 10:15 PM by t3chfaith. 31 replies.
Page 1 of 3 (32 items) 1 2 3 Next >
  • Wed, May 15 2019 11:33 AM
    Media Composer 2018.12.5 AVAILABLE 14 May 2019
    Good news! Media Composer 2018.12.5 is now available. This is a patch release, and is only available through the Download Center. You will not see it in your My Avid account or on Avid Link.
    The Windows version of Media Composer v2018.12.5 is a patch release. You must have v2018.12.3 already installed. Then use the 2018.12.5 patch to update to this release.
    Fixed in Media Composer v2018.12.5
    The following has been fixed:
    ➤ Bug Number: MCCET-2999. You might have received an Exception error when deleting an asset from a bin.
    Fixed in Media Composer v2018.12.4
    The following have been fixed:
    ➤ Bug Number: MCDEV-10783. You might have received errors when trying to log into the MediaCentral Cloud UX server.
    ➤ Bug Number: MCCET-2822. In some instances, the .mxf extension was not appended using Send to Export, therefore “Auto Launch” could not open mxf files.
    ➤ Bug Number: MCCET-2927. Intermittently, saving bins resulted in Exception errors.
    ➤ Bug Number: MCCET-2902. In some instances, a video mixdown included the effects from an upper nested layer.
    ➤ Bug Number: MCCET-2897. After importing, certain WAV files may have had an incorrect start time.
    2
    ➤ Bug Number: MCCET-2748. If a sequence with media from a P2 card was loaded into the Source or Record monitor, relinking to add an extra clip would take too long.
    ➤ Bug Number: MCCET-2867. In some instances, rendering some effects on linked H264 media resulted in mixed up frames.
    ➤ Bug Number: MCCET-2862. (Windows 10) The Audio Tool was not updating when scrubbing with CAPS lock enabled.
    ➤ Bug Number: MCCET-2937. In some instances, if you captured with a single track that was not A1, the capture would abort immediately.
    ➤ Bug Number: MCDEV-10869. Clicking the yellow bin lock icon maximized bins that were minimized.
    ➤ Bug Number: MCCET-2967. (Avid Artist DNxIO and DNxIQ) Audio meter levels were not displayed in the Audio tool when recording.
    ➤ Bug Number: MCCET-2952. The Audio Punch-In Tool did not remember the last bin selected.
    ➤ Bug Number: MCCET-2914. In some instances, when exporting JPG, if you changed the name of the export, the file may have been unusable.
    ➤ Bug Number: MCCET-2942. You could not perform an insert edit export of DNxHR HQX media.
    ➤ Bug Number: MCCET-2946. (Interplay) In some instances, Media Composer would crash during check-in of sequence.
    ➤ Bug Number: MCCET-2910. Importing a non-shared user profile created a duplicate and prevented the application from closing.
    ➤ Bug Number: MCCET-2913. The Property Merge window would inadvertently appear when checking in a clip for first time into Interplay.
    ➤ Bug Number: MCCET-2901. Media Composer would hang when playing back an Avid Titler+ title in the effect editor.
    ➤ Bug Number: MCCET-2729. You might not have received the correct find results when searching group clips in PhraseFind.
    ➤ Bug Number: MCCET-2931. After upgrading from Media Composer v2018.12.1 to v2018.12.2 or v2018.12.3, batch re-import of Matte Key clips was not working.
    3
    ➤ Bug Number: MCCET-2878. The UHD video output is converted to HD when consolidating HD media in a UHD project.
    ➤ Bug Number: MCCET-2859. Switching camera angles in Multicam stopped playback if the group contained mixed frame rates.
    ➤ Bug Number: MCCET-2857. If you were working on a system using Chinese locale, you might have experienced consolidate and transcode audio issues.
    ➤ Bug Number: MCCET-2957. Insert Edit Export failed if only video tracks were selected.
    ➤ Bug Number: MCCET-2966. You might have been unable to import an EDL.
    ➤ Bug Number: MCCET-2915. The metadata might have been incorrect after importing an ALE.
    ➤ Bug Number: MCCET-2841. Saved presets did not always retain the last keyframe.
    ➤ Bug Number: MCCET-2805. The Raster Dimension column in a bin was incorrect for thin raster media.
    ➤ Bug Number: MCCET-2925. In some cases, after performing a render operation, the green dot remained in the Timeline on PNG clips including a Matte Key effect.
    ➤ Bug Number: MCCET-2930. You might have seen performance issues when editing a long AVC Long GOP 25 clip.
    ➤ Bug Number: MCCET-2973. Changes to Audio Reference Level settings changes were not properly reflected when you switched between Normal and Narrow Mixer View.
    ➤ Bug Number: MCCET-2960. (Mac v10.14.x) When linking to media on a shared network drive, the UNC path in the Drive column might have had the network user name in the path.
    ➤ Bug Number: MCCET-2732. When consolidating AVC Long GOP subclips created new master clips that were too long. A new check box has been added to the Consolidate/Transcode dialog
    boxes. Select the “Re-encode AVC Long GOP media to ensure shortest subclip durations” option when you consolidating AVC Long GOP subclips.
    ➤ Bug Number: MCCET-2923. (Mac) You might have received “not authorized” errors when trying to use PhraseFind or ScriptSync.
    ➤ Bug Number: MCCET-2947. You might have received errors when trying to set target the Dynamic Relink settings in an SD 25i PAL project.
    4
    ➤ Bug Number: MCCET-2936. If Dynamic Relink was enabled, imported DaVinci Resolve AAF media was offline.
    Media Composer 2019.12 w/Symphony/SS/PF options, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce... [view my complete system specs]
  • Thu, May 16 2019 1:38 AM In reply to
    • Ramster92
    • Joined on Thu, Jan 11 2018
    • Posts 19
    • Points 255
    Re: Media Composer 2018.12.5 AVAILABLE 14 May 2019
    The cursor bug I reported for 2018.12.4 (after a few commands the cursor does not change to smart tool cursors) is still there...
  • Fri, May 17 2019 12:18 PM In reply to
    Ramster92, I noticed this in 12.4 but didn't have time to report it. I also opened a case for the same thing in 2018.12.5. It happens after you render a few times. The mouse cursor no longer changes from the computer default no matter what tool you are using. You must restart the application to get it to come back. I'm glad I'm not the only one.
    Windows 10 Enterprise - Dell Precision 7820 - 32GB RAM - DNxIQ - Nvidia Quadro P4000 [view my complete system specs]
  • Fri, May 17 2019 4:52 PM In reply to
    • Revenger
    • Joined on Wed, May 11 2011
    • Estonia
    • Posts 90
    • Points 1,115
    +1 to cursor bug.
    MC 2019.12; HP Z800; Windows 10 Pro 64-bit; Dual Quad-Core Intel(R) Xeon(R) X5570 @ 2.93GHz; 24GB (6 x 4GB) DDR3 1333 ECC RAM; NVIDIA Quadro FX 4800 (driver... [view my complete system specs]
  • Sat, May 18 2019 12:29 PM In reply to
    • Joachim Claus
    • Seeheim-Jugenheim, Germany
    • Posts 945
    • Points 12,070
    The patch did not install. I got an error message
    "Database: Transformation: One line is not available and cannot be updated. Table: RemoveFile"
    I uninstalled MC2018.12.3 and re-installed it, however, the patch still creates the same error.
    Why do we not get a full installer?
    Joachim
    Joachim Claus
  • Tue, May 21 2019 6:30 AM In reply to
    • Vilem
    • Joined on Sat, Apr 10 2010
    • Prague
    • Posts 1,410
    • Points 15,525
    Revenger:
    +1 to cursor bug.
    +1
    V.
    AVID MC2019.11 - dongle, HP Z620 - 2 x Intel Xeon E5-2620, Quadro P2000 - driver 441.28, RAM 48GB - DDR3, BM Intensity Pro 4k - 10.11, W10 - 64bit Professional... [view my complete system specs]
  • Tue, May 21 2019 10:20 AM In reply to
    • hsync
    • Joined on Mon, Nov 8 2010
    • Soho, London
    • Posts 19
    • Points 235
    Posted this on the 2018.12.4 thread, is still relevant for .5:
    When you have timecode generator on sequence, and it isn't rendered, when you do a mixdown the timecode field just says n.a. on the mixdown, you need to render it first, then mixdown.
    I think I saw this was identifued as a bug a few point releases back, was hoping it would be fixed on this one, but unfortunately not. Sad
  • Tue, May 21 2019 2:11 PM In reply to
    Hi Joachim, I've got the excat same problem. How did you solved it?
    Media Composer 2019.12 on PC Windows 10 Pro (64-bit), Ryzen™ Threadripper™ 3960X, + 64 Go RAM, Nvidia Quadro P5000 (16Go), DeckLink 4K Extreme 12G, RME... [view my complete system specs]
  • Tue, May 21 2019 7:51 PM In reply to
    • Posts 11,000
    • Points 228,440
    Joachim Claus:
    Joachim
    This is MCCET-3004. Caused by installation of 2018.12.3 on non-English system locale.
    WORKAROUND:
    Switch to the English locale and reinstall MC 2018.12.3, then apply the 2018.12.5 patch.
    fixed in 2019.6
  • Wed, May 22 2019 12:57 PM In reply to
    • Joachim Claus
    • Posts 945
    • Points 12,070
    Marianna:
    WORKAROUND:
    fixed in 2019.6
    I followed your proposal, and made the english version as override version. I made a fresh installation of MC 2018.12.3, checked the content in the file International\xml, and run the patch Update 2018.12.5 with no success. I still get the samde error.
    Joachim
    Joachim Claus
  • Wed, May 22 2019 2:29 PM In reply to
    Is Media Composer v2018.12.5  compatible with macOS 10.14.4??
    Mac OS Mojave ver 10.14.3 iMac Pro (2017) 3.2 GHz Intel Xeon W 32 GB 2666 MHz DDR4 Radeon Pro Vega 56 8176 MB [view my complete system specs]
  • Wed, May 22 2019 8:31 PM In reply to
    • Posts 11,000
    • Points 228,440
    Not yet.
    Should be with 2019.6 coming June 20th
    MM
  • Thu, May 23 2019 8:41 AM In reply to
    Hi all,
    I have found something weird in 2018.12.5.
    I am trying to export a timeline of 47,5 minutes to SD H264. On all the machines that I just had updated to 2018.12.5 I get a error: Exception: Sequence too long.
    So I tested it on one machine that still had my previous version, 8.8.5, same H264 SD export settings. And that just works without getting any exception error.
    In 2018.12.5 I tried to make a audio mixdown on that same sequence and also Exception too long sequence errors.
    Is this a bug? Does anyone else has these kind of problems? This is strange behaviour.
    update
    I have narrowed down my problem. This probleem seems to be groups related. After doing a commit multicam edit I could make mixdown and export again. However I am afraid to use commit multicam after a bug I found on 8.8.5. In that version, if you do a commit multicam edit on a grouped clip that has timewarp effect on it it randomly picks a other shot that is in your project.
    So the solution is: if you run into this problem. Do commit multicam edit before export. Be sure to check if your grouped clips still match with the original sequence to make sure the bug I described above has been solved.
  • Thu, May 23 2019 12:07 PM In reply to
    • Posts 11,000
    • Points 228,440
    Julian Willemsen:
    Hi all,
    update
    Julian
    Let me get a case going to see what support can figure out.
  • Thu, May 23 2019 1:25 PM In reply to
    • Rihafilm
    • Joined on Mon, Jul 19 2010
    • Posts 82
    • Points 1,130
    Marianna:
    Not yet.
    MM
    Hopefully we don't have to wait that long to get a fix for the cursor bug...
    MC 2019.7, DNxIO 11.2, Windows 10 x64 Pro, 2x Xeon E5-2630 v3, Quadro M4000 (431.02), 64GB RAM, RAIDdeluxe 6Gb SAS 96TB 16-bay RAID-6 [view my complete system specs]
