Latest post Sat, May 25 2019 3:51 PM by EvanAA. 4 replies.
  • Thu, May 23 2019 3:32 PM
    • Matthew Clulow
    • Joined on Mon, Feb 12 2018
    • North of Toronto Ontario
    • Posts 32
    • Points 390
    CONFIGURING AVID DNXHD output to quicktime - QUALITY
    Using setting 1080p 29.97 DNXHD 100.
    Unable to change data rate and profile is locked at MEDIUM QUALITY
    Data-rate control is not operable    ?????
    Trying to push best possible quality to You Tube
    Windows 10 Pro Version: 1709 OS Build 16299.192INtel Core(TM) i5-2400 CPU @3.10Ghz 310 GHz8GB Ram - 7.88 usable64 bit x64 based processorDell Optiplex... [view my complete system specs]
    Matthew Clulow
  • Thu, May 23 2019 3:45 PM In reply to
    Re: CONFIGURING AVID DNXHD output to quicktime - QUALITY
    Is there a question in here?
    All DNx flavors are locked to specific standards. There are no variables in the video bitrate or codec that can be altered. If it was customizable, then it would be no longer DNx100.
    We do much of our HD work in that flavor of codec and works well for us.
    If you want to go higher, you can go to DNx145 or DNx220. Changing specs on export take a long time, by the way. It may be better to do a mixdown to the resolution you want and then export "same as source" for the fastest export.
    I hope this helps.
    M. Cebrian
    Windows 10 Enterprise - Dell Precision 7810 - 32GB RAM - DNxIO - Nvidia Quadro M5000 [view my complete system specs]
  • Thu, May 23 2019 4:39 PM In reply to
    • Matthew Clulow
    • Posts 32
    • Points 390
    Thx.   I'll try this
    Matthew Clulow
  • Fri, May 24 2019 10:02 AM In reply to
    X at the end 220X etc indicates that the project could be used for 10bit editing exporting.
    Desktop PC
    3 Heads Digital Films
  • Sat, May 25 2019 3:51 PM In reply to
    • EvanAA
    • Joined on Mon, Mar 7 2016
    • NYC
    • Posts 55
    • Points 710
    I will also add that if you are exporting files that might need to go into other systems like Adobe/PP, Resolve, Etc there can be a strong argument to not use the QT/mov export but to use the Op1a set to the DnX you want.
    Advantages are:
    1)export/import faster
    2)mov files are slowly being supported less.
    3) and main one. seems to eliminate and level shift issues when importing into another system/softwares.
    HP z840, 64gig Ram, 20 cores, GPU k5200, Win10Pro -- Avid Symphony (Since Day 1), Adobe, DaVinci Resolve Studio [view my complete system specs]
