Latest post Fri, Feb 14 2020 8:53 PM by JonRegul. 9 replies.
Page 1 of 1 (10 items)
  • Sat, Sep 21 2019 5:07 AM
    • TrevorA
    • Posts 1,242
    • Points 14,055
    Insert edit export - a great feature
    Currently there is no send to playback at 59.94P, so we have to file export to scan folder to get files to EVS for playout.
    Advantage to this workflow was that we could use, for the first time in anger, ‘insert edit export’. This was great.
    We had to fix our highlights show - 3 little paints in a 12 minute segment. Drop ins take seconds, rather than an 8 minute export.
    Caveats:
    Insert edit export always defaults to export all tracks - you can modify in options to 'selected tracks' but beware:
    a. clicking OK in this option menu goes straight to exporting
    b. the 'selected' video tracks are exported as-is (i.e. select one video track and that is effectively soloed, tracks below are not output)
    c. Exported audio appears to *only* be direct out (limited to number of tracks in file being inserted to). So my accidental audio insert to stereo master was just fx (timeline tracks 1&2) without the commentary (timeline track 3). This would be ok in 5.1/5.1.4 workflow as we’d have had to do a multiple mixdown->direct out export for original file.
    d. You have to choose ‘selected tracks’ every time, it always defaults to all tracks
    Feature requests:
    More visual indication on what is going on with export (what tracks are going to be inserted, what audio configuration is being used).
    Remove ‘use marks’ from options menu as it is redundant
    OK in options menu should   labelled ‘export’
    Cancel in options menu shouldn’t cancel whole export
    Setting to always export using selected tracks
    Selected video shouldn’t solo, should be all tracks below
    Should be an option to insert edit export as mono/stereo/direct etc
    Should be an export option (also for straight file export) for audio to be exported ‘as monitored’
  • Sat, Sep 21 2019 9:07 PM In reply to
    Re: Insert edit export - a great feature
    Yes
    Yes
  • Mon, Sep 23 2019 4:23 AM In reply to
    • TrevorA
    • Posts 1,242
    • Points 14,055
    TrevorA:
    readme for recent version:
    ”. If prompted, select between direct out audio and mixed audio.
    Media Composer will attempt to determine if the original export was done in direct out or by an audio mix, by comparing the tracks layout in the sequence to those in the existing file. In some case, it is unable to tell the difference. , in this case you will have to choose a selection when prompted.”
    So it must have assumed my file was direct out, even that it only had two audio tracks. Bug?
    Points to more info on insert export ahead of performing the edit (eg track selection and audio output config).
    ’Edit review’ would also be useful (link to file, play in to out with pre and post rolll, release file).
  • Mon, Sep 30 2019 9:02 PM In reply to
    • TrevorA
    • Posts 1,242
    • Points 14,055
    Still apparent in 2019.6
    https://www.dropbox.com/s/o3vvvsirujhszl1/Insert%20Edit%20Export%20Audio.mp4?dl=0
    Shows inserting into a stereo file only inserts the first two timeline tracks.
    https://www.dropbox.com/s/87pwe3ozry7cui5/Insert%20Edit%20Export%20-%20Solos%20selected%20track.mp4?dl=0
    Shows how 'use selected tracks' for video effectively soloes the selected track(s) when inserting. Can't imagine why you would want that behaviour
  • Tue, Oct 1 2019 1:37 PM In reply to
    • Joachim Claus
    • Seeheim-Jugenheim, Germany
    • Posts 948
    • Points 12,125
    Until MC 2019.8 there was a bug with Insert Edit. If you had selected "mixdown to Stereo" with the first export of the sequence, Insert Edit only considered the first two tracks and misses all other tracks. This led to corrupted sequences.
    With version 2019.9 this has been solved. Now Insert Edit mixes down all audio tracks to stereo if the first exported sequences was also a mixdown. By doing a mixdown first and then insert it into the existing export file, the result is a correct sequencee with just the part of the sequence replaced with new (correct) tracks.
    Joachim
    Joachim Claus
  • Mon, Oct 7 2019 2:19 PM In reply to
    • TrevorA
    • Posts 1,242
    • Points 14,055
    Joachim Claus:
    Joachim
    Just tested in 2019.9.0
    1. Sequence must be same duration as file being inserted to.
    2. Timecode does not need to match - it will insert based on time from start of sequence/file
    3. Now defaults to 'use selected tracks' and 'include inactive audio tracks' (use marks is redundant).
    4. Clicking OK after choosing options still exports (and so should be labelled as such).
    5. Stereo does now insert correctly but inserting with only audio tracks selected results in: 'Insert edit export failed. File is not supported for insert edit.’ (bug in 2019.9)
    6. Direct insert does not appear to be possible at all (now always mixes down to stereo, regardless of number of tracks in sequence).
    7. Make sure to select all video tracks required - or it will mute those not selected - DANGEROUS
    8. Will insert inactive audio tracks by default (but not muted clips) - DANGEROUS
    9. Ignores timeline solos and mutes - DANGEROUS
    10. Individual clip mutes are respected (a good thing)
    11. Will insert (even though it says it has failed) if file is AMA linked. Better to delete that master clip in Avid before attempting to insert.
  • Tue, Jan 28 2020 10:37 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,653
    • Points 43,980
    TrevorA:
    Joachim Claus:
    Joachim
    Great post Trevor.  Not sure how this relates to your testing on 2019.9.0, but on my system on 2018.12.9 (Mac 10.14.1) file insert edit seems broken - period.
    Just tried to do a very simple V only insert using the workflow that has worked for me before and it acts as if it worked.  I link to the file I modified.  Ok.  I drag the linked file into the source window and start to go to the area of the fix and Avid crashes.
    If I view the file in a non Avid viewer, the fix did not happen.
    This seems to happen consistently.
    Jef
    Jef Huey
  • Wed, Jan 29 2020 11:48 AM In reply to
    The up side of insert to edit not being fully functional yet is it still makes CineXtools a viable option.
    It an extra cost but its the must go to for insert edits.
    Especially if you need UK-DPP AS-11 inserts.
  • Fri, Feb 14 2020 8:53 PM In reply to
    • JonRegul
    • Joined on Wed, Nov 14 2012
    • Posts 4
    • Points 40
    I know it sounds like some of you are having issues with this plug-in, but I'm hoping that there is somebody out there who has experience with this tool that can give me some input so I can decide if perhaps it might be worth it for us. I've used the full CinexTools before, so I have a bit of experience with their products (but not this one).
    1) I know that in order for CinexTools to insert into a ProRes file it has to be a 'padded' file. When using this plug-in to insert into a ProRes file, does it have to re-wrap the entire file (as a 'padded' file) in order to make the insert? Or are you only able to insert into a ProRes file if it is already 'padded'?
    2) In the video demo of this product:
    https://cinedeck.com/videos/?wchannelid=m2ukbwll6o&wvideoid=lo8sfuvrq3
    One of the options listed is to 'insert captions'. Does this plug-in allow you to insert captions into a QT that didn't previously have captions in it? Or does the QT file need to already have captioning embedded for this function to be utilized? And does this have the ability to insert both 608 & 708 captions?
    3) In that same video, when they go to 'AMA File Export', they choose 'Cinedeck Insert', but one of the other options listed there is 'Cinedeck MOV'. Is this just a standard export option that allows you to make things like padded ProRes MOVs and/or MOVs with captions embedded? Has anyone used this export function and can tell me what it is and what options it allows you to do?
    Thanks in advance!
    Jon
