Latest post Wed, Oct 16 2019 12:21 PM by Eric V. 2 replies.
  • Thu, Oct 10 2019 5:04 PM
    • Eric V
    • Joined on Tue, Jun 23 2015
    • Posts 19
    • Points 215
    DNxMXF and metadata
    We are looking into using the new DNxMXF extension to read and write MXF files for interop with MediaComposer. I did not find if or how we can read and write some basic metadata fields. The basic ones we are interested in are:
    - Timecode
    - Material, Source and Original Source Package UIDs
    - Tape/Reel name
    Is the plan to augment the SDK to support these fields?
    Eric
  • Wed, Oct 16 2019 11:39 AM In reply to
    • ViktorB
    • Joined on Wed, Mar 20 2019
    • Posts 7
    • Points 55
    • Avid Developer Moderator
      Avid Employee
    Re: DNxMXF and metadata
    Hello Eric,
    Eric V:
    - Timecode
    - Tape/Reel name
    Timecode - yes, this is planned for the next DNxSDK release
    Material, Source and Original Source Package UIDs, Tape/Reel name - no plans to support.
    The DNx MXF interface is intended for clients who have no MXF-specific processing needs and only require a standardized way to read/write DNx-encoded essence from/into a file format which can be read/written by other applications without problems (by virtue of the DNx MXF interface). It is explicitly not intended as a replacement of a full-featured MXF SDK, which allows explicit control over MXF-specific details, or as a replacement for the Avid Media Toolkit (AMT) Media Composer interop API (available free of charge for DNx from Avid). The DNx SDK will only support generic metadata (non-MXF specific) and only to the extent that they are defined in SMPTE ST 377-1. None of the requested elements qualifies under these criteria.
    As the question is about Media Composer interop we strongly advise the use of AMT, which is provided specifically for this use.
    Viktor
  • Wed, Oct 16 2019 12:21 PM In reply to
    • Eric V
    • Posts 19
    • Points 215
    Hi Viktor,
    I understand. We are looking for a solution that works on Linux (and Mac)...
    Eric
