Latest post Thu, Nov 14 2019 3:50 PM by Adri Vermeulen. 2 replies.
  • Tue, Nov 12 2019 4:13 PM
    Is there a difference between the Rename and SetAttribute DisplayName?
    With the SetAttribute operation you can change the name of a Assest (DisplayName).
    There is also a Rename operation.
    Is there any difference between those two?
    I want to change the name and also change other attributes at the same time.
    Which is possible with the SetAttribute operation.
    Is there a downside of using the SetAttribute for changing the name of a folder?
    Thanks, Adri Vermeulen
  • Tue, Nov 12 2019 6:15 PM In reply to
    Re: Is there a difference between the Rename and SetAttribute DisplayName?
    Hello Adri,
    In the case with Production Asset Management doesn`t matter which method you`re using.
    But in other systems, it might be different effects for both methods. It depends on the implementation of a particular service.
    TY/Vlad.
  • Thu, Nov 14 2019 3:50 PM In reply to
    TY/Vlad, there is a difference, I notice.
    Rename change also the Path
    Where Set DisplayName sets only the Display Name and keep the old name as path
    Thanks for you response, Adri Vermeulen
