Latest post Tue, Mar 10 2020 8:51 PM by camoscato. 32 replies.
Page 1 of 3 (33 items) 1 2 3 Next >
  • Mon, Dec 23 2019 6:45 PM
    Media Composer 2019.12 Available - 23 Dec 2019
    Updates to Media Composer 2019.12 are available from Avid Link, MyAvid and the Avid Download Center (login and password required).
    Status of Support Plan: The ability to launch this Media Composer 2019.12 software is dependent on the status of a customer’s Upgrade and Support Plan on the date this software version is released. Media Composer 2019.12 has been released today, December 23, 2019.
    What’s Changed in 2019.12:  The following has changed in Media Composer v2019.12.
    • Show Bin in Sidebar
    • Inspector Tool Update
    • OpenEXR Export Support
    • Avid Titler+ Updates
    • Media Composer and Distributed Processor Worker on the Same System
    • Media Composer | Enterprise Settings Update
    • Updated ACES Support
    What New Document:  The What’s New Document for Media Composer 2019.12 has been uploaded to the Knowledge Base.
    What’s Fixed in 2019.12:  Below is the list of items fixed.
    Bug Number: MCCET-3285. With connected IO hardware such as AJA or Blackmagic, you could not downscale monitor output on an HD client monitor.
    - Bug Number: MCDEV-11345. When tools were tabbed with the Composer Window, the video displayed on top of the tools.
    - Bug Number: MCCET-3374. Bin sifting was not retained after closing and opening the bin.
    - Bug Number: MCDEV-12014. Sometimes when the Audio Mixer was layered over another tool or bin, and the Timeline or Composer had focus, hovering the mouse over the Audio Mixer made the Audio Mixer the active window.
    - Bug Number: MCDEV-12015. Minimizing Media Composer on dual monitors with auto hide sometimes resulted in losing Menus, Workspace Bar, and background host panel.
    - Bug Number: MCCET-3210. The Source Record monitor would go black, and menus stopped working if you were working with the Source Browser and the Windows taskbar was set to auto-hide.
    - Bug Number: MCDEV-12099. Thumbnails for subclips were recaching every time you opened a bin in Frame View, slowing performance.
    - Bug Number: MCDEV-12347. With large projects on shared storage, updating the project after changing a bin name was slow.
    - Bug Number: MCCET-3305. You might have received a “Cannot find bin x in Project x” when performing a Find Bin.
    - Bug Number: MCCET-3108. The text to identify locked bins was not displayed in bold.
    - Bug Number: MCCET-3299. Using JKL did not work properly when playing a clip with a Timewarp effect.
    - Bug Number: MCCET-3355. Imported tga files were only one frame in duration.
    - Bug Number: MCCET-3304. Newly created bins that were empty did not save size nor position when working with shared storage.
    - Bug Number: MCCET-3206. In some instances, clip frames would rebuild on the entire sequence.
    - Bug Number: MCCET-3388. You could not resize an effect +/- 10 steps using the keyboard shortcuts.
    - Bug Number: MCCET-3369. French, Swedish, German, and Danish letters in Bin Script View comment field didn’t display properly.
    - Bug Number: MCCET-3333. Sequential Targa (.tga) files could not be imported correctly.
    - Bug Number: MCCET-3337. When right-clicking on linked clips in a bin, the Relink to Files option might have been grayed out.
    - Bug Number: MCCET-3404. (NRCS Tool) When browsing iNews database, the cursor continued showing a spinning wheel even after the result had been returned.
    - Bug Number: MCCET-3292. A Transition did not play correctly in full quality if the first clip was an imported still image with XDCAM HD or AVC Long GOP.
    - Bug Number: MCCET-3399. The position info did not display even if you selected Settings > Grid > Display > Show Position Info.
    - Bug Number: MCCET-3372. Media Composer became unresponsive when you tried to perform a transfer to a Transfer service that was not available.
    - Bug Number: MCCET-3342. If Waveforms were enabled, the Timeline responsiveness lagged when dragging or trimming.
    - Bug Number: MCCET-2817. Trimming a clip with an AudioSuite Time compression/expansion effect might have affected subsequent renders.
    - Bug Number: MCCET-3251. In some instances, Media Composer vaporized when extracting a segment.
    - Bug Number: MCCET-3330 (Avid Artist DNxIO, Avid Artist DNxIQ). In some instances, 720p25 projects were incorrectly converted to 1080i50.
    - Bug Number: MCCET-3230. Timecode Burn-in added pulldown frame info when added to V5 or V6 track.
    - Bug Number: MCCET-3306. In some instances, if the Effects Editor was open, Color Correction was not always added correctly, and the wrong clip was modified.
    ReadMe:  The ReadMe for this release was uploaded to the Knowledge Base.
    How to obtain the Media Composer 2019.12 Update: The new Media Composer 2019.12 iavailable as follows…..
    1.  Customers who have an active support and upgrade plan will be notified of the availability of the 2019.12 via Avid Link and it will be available via Link, MyAvid and the Download Center.
    2.  New perpetual and subscription Licenses purchased on or after Monday December 23, 2019 will also receive 2019.12.
    Media Composer 2019.12 w/Symphony/SS/PF options, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce... [view my complete system specs]
  • Tue, Dec 24 2019 2:37 PM In reply to
    • Yuri
    • Joined on Thu, Jun 22 2006
    • Moscow
    • Posts 17
    • Points 255
    Re: Media Composer 2019.12 Available - 23 Dec 2019
    Excuse me, This release is also an "AC3" issue. Is that so?
    In Console->
    "AVCHD MSP Plug-In: AVCHDSampleProvider::ProvideSampleRange AC3 CODEC is not available: producing silence.
    [AVCHD MSP Plug-In] AC3 CODEC is not available: producing silence."
    Asus_X99-E_WS i7-5960X 32Gb_DDR4 GTX750Ti GTX1070 BM_DecklinkHDExtreme3D+ Win10_1809,MediaComposer Subscribe 2019.12 [view my complete system specs]
  • Wed, Dec 25 2019 4:42 AM In reply to
    Great to see targa sequence import is back...that was missed and is working fine now.  thank you.
  • Fri, Dec 27 2019 4:16 PM In reply to
    • Posts 10,994
    • Points 228,340
    Robert Martindale:
    I'll mak sure I let Engeering know.... thanks for the thanks Robert.
  • Fri, Jan 3 2020 8:52 PM In reply to
    Hi!
    Is there any way to use Canon XF-705 camera 3840x2160 / 50p format X-HVC coded material on AMA link across MC 2019.12 under Win10 64bit
    Thank you in advance for your help!
    Best Regards: ejg1964
    HP Z800, 2xX5650 Xeon Six Core CPU, 48GB 1600MHz ECC Registered RAM, Quadro M4000 VGA, DeckLink Studio4K, [view my complete system specs]
  • Sat, Jan 4 2020 1:29 AM In reply to
    • touviere7
    • Joined on Mon, Mar 15 2010
    • los angeles
    • Posts 659
    • Points 7,470
    was it 4:2:2 10bit or 4:2:0 8 bit?
    the 4:2:2 10 bit is H265 - no go in avid as it doesn't recognize H265 (yet or ?...)
    the 4:2:0 8 bit is H264 - good to go
    symphony 2019.12 - win 10 pro64 v.1909 - QT essential 7.7.9 - nVidia gtx1080 OC (441.66) - intel i7 6800k@4.1ghz water cooled by corsair H100i V2 - MSI... [view my complete system specs]
  • Sat, Jan 4 2020 1:57 PM In reply to
    Hi!
    Format settings, wrapping mode           : Frame
    Codec ID                                 : 0E15000402100001-0E15000500013000
    Duration                                 : 14 mp 400emp
    Bit rate                                 : 152 Mb/s
    Width                                    : 3 840 képpont
    Height                                   : 2 160 képpont
    Display aspect ratio                     : 16:9
    Frame rate                               : 50,000 FPS
    Color space                              : YUV
    Chroma subsampling                       : 4:2:2
    Bit depth                                : 10 bit
    Scan type                                : folytonos
    Bits/(Pixel*Frame)                       : 0.367
    Stream size                              : 261 MiB (97%)
    Color primaries                          : BT.2020
    Camera: Canon XF-705 X-HVEC codec
  • Sun, Jan 5 2020 12:43 AM In reply to
    • cls105
    • los angeles
    • Posts 485
    • Points 6,240
    Here is a bug on this version.  It was in the last versions too.
    If you have a bin with a bunch of clips and you write something in the comment column, you don't see the text updating as your're typing.  You only see the text you've written once you hit return.  This is on mac and pc.
    Thank You
  • Sun, Jan 5 2020 1:00 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,734
    • Points 61,780
    cls105:
    Thank You
    Not seeing this - is there a set of steps you could describe just in case I am misunderstanding?
    Camera(s) PXW-X70, HDR-FX1, Hero 6 Black | MC 2019.12 | QT 7.7.9 | Continuum 2020 | Sapphire 2020 | Mocha Pro 2020 | Titler Pro 7 | Windows 10 Pro x64... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Sun, Jan 5 2020 3:29 PM In reply to
    I think there is something misunderstanding.
    He gave me a material that was shot with a Canon Xf-705 camera.
    The codes are Canon X-HEVC, 3840x2160p50 with 4: 2: 2 sampling rate with MXF (OP1A) 152Mbps.
    MC 2019.2 can neither link nor import via Canon AMA 3.5.
    The Canon XF Utility, version 3.5 with the Canon X-HEVC 1.0 decoder, can be used to script nicely.
    I deduce from this that AVID MC 2019.12 is not suitable for cutting the material of a camera released more than a year ago. I think this is outrageous neglect by za AVID.
    What is the solution to this problem?
    Preliminary file conversion excluded!
    I hope I am well aware of my problem.
  • Sun, Jan 5 2020 9:13 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,727
    • Points 47,750
      Moderator: MCA Mac
    Enyedi,
    Please see this link: http://community.avid.com/forums/p/186499/877872.aspx#877872. It may help.
    DIY quad core I7-4790K, 32Gb, NVidia RTX 2060 Super 8, Win 10 Pro, MC(generally the latest or the one just before), MC 7.x [view my complete system specs]
    Dave S.
  • Mon, Jan 6 2020 6:13 PM In reply to
    Hi!
    The topic mentioned does not provide any solution to the problem, just a try. So there was no CANON XF-705 X-HEVC source material available. Do I still ask AVID experts if they haven't been able to find a workable solution in more than a year? So far, the collaboration between Canon and AVID has been exemplary in the coherence of product development. What can happen? Why do our users see the damage to their inertia?
    Filed under: , ,
  • Tue, Jan 7 2020 3:21 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,727
    • Points 47,750
      Moderator: MCA Mac
    Enyedi,
    In that same thread that I pointed to, Powerfreak reports that it does work with the XF-705. He's not using the AMA plug-in from the Avid website, but one from the Canon website. Here's the link:
    https://my.canon/en/support/0200574916/2
    Dave S.
  • Wed, Jan 8 2020 1:04 PM In reply to
    Hi!
    The above link says it was supposed to work because they couldn't test it. They had no XF-705 Matter. I've also downloaded both the Utility and the Canon Media Access for AVID AMA plugin from Canon. version 3.5. Today I tried it on an HP z420 AVID certified workstation on MC2019.12 but still not working.
    I continue to ask that AVID and CANON do not resolve this issue together. so I don't want to use Edius for my work.
    https://www.canon.hu/support/consumer_products/products/camcorders/digital/hdv_series/xf705.html?type=download&language=&os=windows%2010%20(64-bit)
    Filed under: ,
  • Fri, Jan 10 2020 2:36 AM In reply to
    • DStone
    • Massachusetts
    • Posts 3,727
    • Points 47,750
      Moderator: MCA Mac
    Enyedi,
    Can you upload some Xf705 media for testing? Also, Powerefreak (in the other thread) had tested it and reported that it does work. What is your workflow for ingesting the Canon media?
    Dave S.
