Latest post Wed, Apr 8 2020 10:13 AM by camoscato. 34 replies.
Page 2 of 3 (35 items) < Previous 1 2 3 Next >
  • Sun, Jan 12 2020 1:41 PM In reply to
    Re: Media Composer 2019.12 Available - 23 Dec 2019
    Hi!
    The rotated material is saved to the local disk using version 3.5 of XF-Utility, and AMA is version 3.5.
    I'll send you a link where there are raw materials.
    http://media.ttre.hu/?dir=sources/XF705
    Thank you in advance for your help!
    Best Regards: Gabor
    HP Z800, 2xX5650 Xeon Six Core CPU, 48GB 1600MHz ECC Registered RAM, Quadro M4000 VGA, DeckLink Studio4K, [view my complete system specs]
    Filed under: , ,
  • Mon, Jan 13 2020 5:12 AM In reply to
    • DStone
    • Massachusetts
    • Posts 3,738
    • Points 47,905
      Moderator: MCA Mac
    This comes back to the first post I made in this thread. You need to install both the AMA plugin and the HEVC decoder from Canon. Installing the plugin by itself won't work. Before linking, right-click on the media in the source browser and use Link with Canon hevc.
    Please note that while I can sucessfully link to the HEVC files, I am unable to play them. My system is giving me the SFPlayConsumer::Execute TIMEOUT error.
    Dave S.
  • Mon, Jan 13 2020 3:22 PM In reply to
    • cls105
    • los angeles
    • Posts 509
    • Points 6,550
    I am in tabbed bin mode.
    If I double click a bin, it opens in a tab.  If I match frame from sequence then reveal in bin, it floats the bin.
    I feel like this behavior should be consistant with what ever the double click is (it quickly turns messy if not).
    Or is there a setting for how the bin will be opened when revealing/finding in bin?
    thx
    w10, mc 2020.4, diy x299 7940x [view my complete system specs]
  • Tue, Jan 14 2020 10:47 PM In reply to
    • Cutyes
    • Joined on Sat, Jan 14 2012
    • Berlin
    • Posts 166
    • Points 2,165
    cls105:
    If one has two or more bin containers open 'Find Bin' wouldn't know which bin container to assign the bin to. Whereas the double-click's target container is defined by the double-click itself. Automatically assigning the last active container to the 'Find Bin' command could do the trick though. (Depending on the double click setting, as you said.) Just like 'Make Subclip' creates the subclip in the last active bin.
    cls105:
    Just in case you didn't know: you can alt-drag a floating bin into an open container. You don't have to keep them floating.
  • Sat, Jan 25 2020 6:49 PM In reply to
    • Vince
    • Posts 16
    • Points 200
    Does this version of Avid MC (2019) for PC have the ability to export to ProRes 422? If it does, please provide a link to the documented workflow.
    According to the below link, Avid supports ProRes export on windows:
    https://www.avid.com/press-room/2019/09/avid-delivers-video-editing-workflows
  • Tue, Jan 28 2020 2:46 PM In reply to
    • cls105
    • los angeles
    • Posts 509
    • Points 6,550
    1st frames of audio on timeline still arent played sometimes.
    I don't know if its not buffering audio clips correctly or what.
    But many times I have to replay a certain section of the timeline, so I hear the beginning of the audio clips.
    thx
  • Fri, Feb 7 2020 6:04 PM In reply to
    • cls105
    • los angeles
    • Posts 509
    • Points 6,550
    after I add a locator on a timeline it i have to reclick the record monitor or timeline to be able to add locators again.  Very annoying when adding locators to a stringout.
  • Sat, Feb 8 2020 2:40 PM In reply to
    • LDV20
    • Joined on Fri, Nov 18 2011
    • Posts 266
    • Points 3,175
    Vince:
    I also would like more information on this - what is the workflow?
    Symphony 2019.12- Win 10 pro (1809), Asus PrimeZ270 with i7 7700 cpu, Quadro P2000,(431.02) 64gig memory, 500gig SSD system drive, WD 5TB,and 2TB media... [view my complete system specs]
  • Tue, Feb 11 2020 7:21 PM In reply to
    • mkj
    • Sweden
    • Posts 452
    • Points 5,965
    Is it safe to go from 2018 to 2019 now?
    I'm responsible for 50+ edit computers, and have no time for trouble...
  • Thu, Feb 13 2020 12:49 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,736
    • Points 61,790
    mkj:
    Are you already familiar with the changes in the 2019 interface? Also - whether you upgrade may have more to do with your preferred workflow so it would be best to do the upgrade on a couple of machines as a test of both UI and workflow before you upgrade all. My 2 cents.
    Camera(s) PXW-X70, HDR-FX1, Hero 6 Black | MC 2019.12 | QT 7.7.9 | Continuum 2020 | Sapphire 2020 | Mocha Pro 2020 | Titler Pro 7 | Windows 10 Pro x64... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Thu, Feb 13 2020 8:47 PM In reply to
    • mkj
    • Sweden
    • Posts 452
    • Points 5,965
    is it possible to work with the same project (Nexis) with 2018.12.10 & 2019.12?
  • Fri, Feb 14 2020 7:22 PM In reply to
    • cls105
    • los angeles
    • Posts 509
    • Points 6,550
    Since my bins are on my left monitor (composer + timeline on center, and full screen playback on right).  I think it could be interesting if the bin sidebar could be on the right side.  That way I wouldnt have to look all the way to the left of my left monitor to open my bins.
  • Mon, Feb 17 2020 3:14 PM In reply to
    • JRijken
    • Joined on Fri, Sep 21 2018
    • Belgium
    • Posts 19
    • Points 285
    cls105:
    thx
    +1 a number of my editors have been experiencing the same issue.
    HP z4, Avid MC 2018.10, 64GB RAM,NVidea Quadro M4000, Windows 10 pro, BM decklink extreme 4k 12G. [view my complete system specs]
  • Sat, Feb 22 2020 11:46 AM In reply to
    • mkj
    • Sweden
    • Posts 452
    • Points 5,965
    mkj:
    anyone?...can you mix 2018 & 2019 clients in one shared project?
  • Mon, Feb 24 2020 11:21 PM In reply to
    • Vince
    • Posts 16
    • Points 200
    Any response from Avid support?  Does MC 2019 suport export to ProRes from Windows 10?
