Latest post Wed, Feb 12 2020 11:28 PM by mtahir. 14 replies.
Page 1 of 1 (15 items)
  • Mon, Dec 30 2019 4:12 PM
    • Thomas K.
    • Joined on Mon, Nov 9 2009
    • Posts 5
    • Points 115
    No AC3 audio (Dolby) again... after installing 2019.12
    After installing MC 2019.12 there is no audio in avchd  MTS files (AC3 / Dolby). I remember, that there was this bug some time ago. Previous versions up to 2019.11 are fine, just the latest one is not working anymore.
    Any suggestions?
    ThanksTom
    win10
    Filed under: , ,
  • Tue, Dec 31 2019 2:33 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 2,123
    • Points 23,615
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Re: No AC3 audio (Dolby) again... after installing 2019.12
    Hi Thomas,
      I'm creating a case for this so we can check this.
    RalphC
  • Thu, Jan 2 2020 12:53 PM In reply to
    • Yuri
    • Joined on Thu, Jun 22 2006
    • Moscow
    • Posts 17
    • Points 255
    I also have this problem!
    ありがとございます。
    Asus_X99-E_WS i7-5960X 32Gb_DDR4 GTX750Ti GTX1070 BM_DecklinkHDExtreme3D+ Win10_1809,MediaComposer Subscribe 2019.12 [view my complete system specs]
  • Thu, Jan 2 2020 4:17 PM In reply to
    • RalphC
    • Posts 2,123
    • Points 23,615
      Avid Employee
    Hi Yuri,
      Please send me an email I will open a case for you. Thanks!
    RalphC
  • Thu, Jan 2 2020 6:07 PM In reply to
    • touviere7
    • Joined on Mon, Mar 15 2010
    • los angeles
    • Posts 659
    • Points 7,470
    after testing, i can confirm no audio with avchd on 2019.12  on my system as well (linked or imported).
    symphony 2019.12 - win 10 pro64 v.1909 - QT essential 7.7.9 - nVidia gtx1080 OC (442.19 studio) - intel i7 6800k @4.2ghz water cooled by corsair H100i... [view my complete system specs]
  • Thu, Jan 2 2020 6:37 PM In reply to
    • RalphC
    • Posts 2,123
    • Points 23,615
      Avid Employee
    touviere7:
      Can you also send me an email include MC systems ID for the case.
  • Thu, Jan 2 2020 7:21 PM In reply to
    • touviere7
    • los angeles
    • Posts 659
    • Points 7,470
    ralph,
    id sent.
     by the way, i don't use avchd, but just did a quick test out of curiosity.
  • Thu, Jan 2 2020 9:31 PM In reply to
    *edit* My bad, 2018.7 and up should auto-activate AC-3.
    Does this still work?
    http://avid.force.com/pkb/articles/en_US/user_guide/How-do-I-activate-AC3-with-Media-Composer-8-0-and-Avid-Application-Manager
    https://my.avid.com/products/indirectactivation/optionalfeatures
  • Fri, Jan 3 2020 8:47 PM In reply to
    • touviere7
    • los angeles
    • Posts 659
    • Points 7,470
    well, obviously, not for everyone, job.
    application manager was replaced with avidl ink...
    where could we find the code to try activating ac3 with avid link manually?
  • Wed, Jan 8 2020 2:00 PM In reply to
    • RalphC
    • Posts 2,123
    • Points 23,615
      Avid Employee
    We have a bug logged for this MCCET-3434. Hopefully next update this will be fix.
    RalphC
  • Thu, Jan 9 2020 3:04 AM In reply to
    • touviere7
    • los angeles
    • Posts 659
    • Points 7,470
    thanks!
  • Tue, Feb 11 2020 3:24 PM In reply to
    • J. Koehler
    • Joined on Sat, Oct 27 2018
    • Berlin / Germany
    • Posts 9
    • Points 115
    same for me.
    can you provide a provisionally workarround to active the ac3 / dolby plugin? (need it tomorow)
    Avid MC 2019.12 Mobile System Win10Pro Dell XPS 9569 4K - i7 7700HQ - Nvidia GTX1050 4GB 16GB RAM - 512GB... [view my complete system specs]
  • Tue, Feb 11 2020 5:33 PM In reply to
    • J. Koehler
    • Berlin / Germany
    • Posts 9
    • Points 115
    Memory stats: physical = 16235 MB, virtual = 134217727 MB, restriction = 0 MB
    WARNING: Requested LocateBuffer size 2048MB is the same as current size 2048MB.
    Set persistent image cache limit: 200.0 MB in C:/Users/Public/Documents/Avid Media Composer/AvidImageCache
    AWin32Mixer::Open inputMixerID = 1
    Created ADM Device : 1394 Audio
    DirectSound ADM running on Windows OS Version Major=6 Minor=2 Build=9200
    Created ADM Device : DirectSound Audio
    AlertableTimer Win32 constructor, default system clock resolution min = 1, max = 1000000
    MCBootstrap::gwhoami = 30
    Duplicate definition entry (not added)
    Plugin definition registration failed
    Avid Media Access: Device monitor successfully initialized
    AVX Library V1.5
    OpenGL implementation found:
    vendor = Brian Paul
    renderer = Mesa OffScreen16
    version = 1.5 Mesa 6.4
    This OpenGL implementation does not support hardware texture render
    maximum render dimensions: = 1920 x 1080 at 8 bits per pixel channel
    vendor = NVIDIA Corporation
    renderer = GeForce GTX 1050/PCIe/SSE2
    version = 4.6.0 NVIDIA 441.45
    This OpenGL implementation supports hardware texture render
    AME CPU Buffer Deallocator Registered Successfully
    AME GPU Buffer Deallocator Registered Successfully
    MonCon Painters: GPU, CPU
    ACPL Transfer Type: OGL
    ACPL Transfer Buffer Type: Persistent
    ACPL Transfer Mode: NonOverlapped
    ACPL GPU Memory Pool Capacity: 1536 MB
    ACPL GPU Memory Pool Host Capacity: 1024 MB
    ACPL GPU Private Memory Pool Capacity: 1536 MB
    ACPL GPU Private Memory Pool Host Capacity: 0 MB
    ACPL GPU VRAM Capacity: 4096MB
    Newer CPU<->GPU bus speeds detected (4.8166)
    AAF DLL loaded from : C:\Program Files\Avid\Avid Media Composer\AAFCOAPI.dll
    AAF DLL version : 2.0.6 (10030) [1]
    DFM loaded. 194 entries initialized. Scripts directory 'C:\Program Files\Avid\Avid Media Composer\SupportingFiles\CodecToolkit_Config\'
    Setting chained toggle /Q7Container/EnableInternalProcessing_H264:true
    Setting chained toggle /Q7Container/EnableInternalProcessing_AAC:true
    Setting chained toggle /Q7Container/EnableInternalProcessing_MJPEG:true
    Setting chained toggle /Q7Container/EnableInternalProcessing_TIFF:true
    Setting chained toggle /Q7Container/EnableInternalProcessing_JPEG:true
    Setting chained toggle /Q7Container/EnableInternalProcessing_PCM:true
    Setting chained toggle /Q7Container/EnableInternalProcessing_ProRes:false
    Setting chained toggle /Q7Container/EnableInternalProcessing_MPEG-2:false
    Setting chained toggle /Q7Container/EnableInternalProcessing_DNxHR:false
    Setting chained toggle /Q7Container/EnableInternalProcessing_DNxHD:false
    Setting chained toggle /Q7Container/EnableInternalProcessing_Alpha:true
    Setting chained toggle /Q7Container/EnableInternalProcessing_RLE:false
    Setting chained toggle /Q7Container/SupportMediaWithRoundedTrackLength:true
    Setting chained toggle /Q7Container/RedirectToQ7_26_IfAvailable:false
    Setting chained toggle /Q7Container/RedirectMediaWithRoundedTrackLengthToQ7_26_IfAvailable:false
    Setting chained toggle /Q7Container/Disable16BitImageFormatsSupport:false
    Setting chained toggle /GenericMXFContainer/MXFSuppressMCAMetadata:false
    Setting chained toggle /GenericMXFContainer/OverrideUnsupportedDistinguishedFrameLayout:true
    Setting chained toggle /Q7Container/TruncateMasterMobEssenceSlotsToMinumumCommonDuration:false
    Setting chained toggle /Q7Container/TreatVariableFrameRateAsConstantAverage:true
    Setting chained toggle /QuickTimeMediaContainer/TruncateFractionalStartOffsetsToFullFramePrecharge:true
    Setting chained toggle /AMPPlugin/Enable_DNx:true
    Setting chained toggle /AMAFI-SDK/DisableLoggingErrorMessagesOnContainerHandlerProbing:true
    Setting chained toggle /Q7Container/RedirectMediaWithMasterMobFillerToQ7_26_IfAvailable:false
    Setting chained toggle /AMPPlugin/Enable_DCP_J2K:false
    Setting chained toggle /AMPPlugin/Enable_IMF_J2K:true
    Setting chained toggle /AMPPlugin/Enable_J2K:true
    Setting chained toggle /AMPPlugin/Enable_DV_Based:true
    Setting chained toggle /AMPPlugin/Enable_CAT_AVCI:true
    Setting chained toggle /AMPPlugin/Enable_H264_Proxy:false
    Setting chained toggle /AMPPlugin/Enable_DNxU:true
    Setting chained toggle /AMPPlugin/Enable_ProRes:false
    Setting chained toggle /AMPPlugin/Enable_DNxHD_VCID:true
    Setting chained toggle /AMPPlugin/Enable_CAT_DNxHR:true
    Setting chained toggle /AMPPlugin/Enable_CAT_DNxHD:false
    Setting chained toggle /GenericMXFContainer/SetDefaultLengthInStaticSlotComponents:true
    Setting chained toggle /GenericMXFContainer/EnableRedirectionToAvidOPAtom:false
    Setting chained toggle /WaveAiffReaderMovMediaContainer/AudioTimecodeUseBEXTOriginationDate:false
    Setting chained toggle /AMAFI-Tiff/TiffReturnCompressedEssence:false
    Setting chained toggle /AMAFI-SDK/DisableVariableFrameRateModeForTruncatedEssence:true
    Setting chained toggle /WaveAiffReaderMovMediaContainer/BigEndianSmpteIdInBEXTData:false
    BigBufferPool 0x000000010C1ACCA0:
    Total Free: 2147483648 (2.00G)
    Largest Free: 2147483648 (2.00G)
    Memory Chunk 0x000000010C34A3F0, ADDR=[0x00007FF304E30000]
    Number Allocs: 0
    Max Allocs: 0
    MSM directories:1
    LocalMDB::LoadMobsFromMDB() inCallback=0000000000000000 sourceOnle=FALSE
    mediaDirPath phyMobs logMobs
    "C:\Users\Public\Documents\Avid Media Composer\Avid_MediaFiles\" 0.01 sec
    total time=0.01 mobs=0
    Media Drives:
    XPS (C:), OSVolID = 67, 486835196 totalKB, 390876424 freeKB, 390112994 realFreeKB
    COM2: error (2) Das System kann die angegebene Datei nicht finden.
    MAX_INDEXES_TO_READ set to 10240
    MXF Indexes in Memory changed to 524288000: Old Size 524288000
    In Init ARO Cmds
    MTSC state = 0The single frame player will be built for a length of 3600 frames
    Viewer: OpenCL and OpenGL are compatible
    MSMRescan() took: 0.009000s
    WARNING: BigBufferPool::ResizePool did NOT allocate enough, Requested 3072MB Actual 0MB
    LocateBuffer Resize from 2048MB to 2048MB
    The default render wait time is 50
    MSMRescan() took: 0.005000s
    Cannot get master mob duration from the Format Descriptor
    Cannot get the source clip length from the Format Descriptor
    Link To AMA Volume -> E:\
    MVP Used:[ Plugin Name = AVCHD MVP Plug-In Avid Technology, Inc. Version = 1.5.7.10174 ]
    MSP Used:[ Plugin Name = AVCHD MSP Plug-In Avid Technology, Inc. Version = 1.5.7.10174 ]
    AMA link to volume E:\ was successful.
    Reloading plugin: ByteBlock.avx
    AVCHD MSP Plug-In: AVCHDSampleProvider::ProvideSampleRange AC3 CODEC is not available: producing silence.
    [AVCHD MSP Plug-In] AC3 CODEC is not available: producing silence.
    AVCHD MSP Plug-In: _syncReader::Read read less than requested: read:780864 requested:1350144, ??????????????????????????????????????????????????(538)
  • Tue, Feb 11 2020 7:44 PM In reply to
    • mtahir
    • UK
    • Posts 503
    • Points 6,120
    I can confirm that I'm getting the same issue with 2019.12:
    BuildPipes Concurrency Alert - BuildPipes starting with BuildPipes in progress!
    Regards
    Mohammed
    MC2019.12 (Win7) | Dell T7500 with 2 x 6-Core Intel Xeon X5690 3.46GHz CPUs | Triple-Channel 64GB (32GB per CPU) 1333MHz DDR3 EEC FBDIMM | 3GB nVidia Quadro... [view my complete system specs]
    Filed under: ,
  • Wed, Feb 12 2020 11:28 PM In reply to
    • mtahir
    • UK
    • Posts 503
    • Points 6,120
    For those that want to use AVCHD files in MC with this current AC3 problem, you could try this. It's a script based on FFMBC that will convert the audio in the AVCHD to PCM but leave the video alone. The resulting file is a MOV file that will have the same name as the source file. It will convert all the AVCHD files in the directory it's run from.
    Instructions:
    1. Download the zip file here.
    2. Unzip all the contents in the folder that you have your AVCHD files.
    3. Open a CMD console and navigate to the folder with the AVCHD files.
    4. Run the .BAT file.
    5. When linking in MC, select the MOV file(s), right click and select the Quicktime plugin. This step is important. MC won't pick the Quicktime plugin up by default.
    Give it a try and I hope it helps.
    Regards
    Mohammed
    Filed under: , ,
