Latest post Sun, Jan 26 2020 7:52 PM by krossa. 2 replies.
  • Sun, Jan 26 2020 12:28 AM
    • krossa
    • Joined on Fri, Jan 24 2020
    • Posts 6
    • Points 60
    ACCESS VIOLATION error while editing in the timeline
    While adjusting audio levels in my timeline, my cursor and screen suddenly froze up (I suspect that I may have pressed the space bar for playback an instant before releasing a mouse click) I was unable to access Task Manager to shut down, so after a few minutes I powered off.
    After restarting my PC I loaded MC. The startup process appeared orderly until the point at which MC loads the sequence I had been working on. It failed to load and an "ACCESS VIOLATION exception occured" message was displayed. When I dismissed the error message another one appeared and MC crashed.
    At this point I was able to shut down MC via Task Manager, and on a subsequent attempt I was able to load and navigate freely around MC. I was able to open several bins, but my attempt to open the bin containing the sequence in question resulted in another crash.
    In searching the forum extensively, I found a few potential strategies for resolution of ACCESS VIOLATION errors in general, but because most of those cases were triggered by moving files around I'm a bit uncertain how apt they might be to my situation. That is, in my case I was simply editing in the timeline at the time of the crash, so maybe this requires a different solution.
    I've been using MC for the past few years in the same configuration without incident, so I'm unsure of the nature of the problem and how to approach its resolution. Any insights from the community would be greatly appreciated.
    Media Composer v.6.0; Win7 x64 Pro*, on HP Z210 Workstation: Intel Xeon E31240 @3.3GHz, 8GB RAM, NVIDEA Quadro 2000. Media on Hitachi G-Raid 4TB. *isolated... [view my complete system specs]
  • Sun, Jan 26 2020 4:58 PM In reply to
    • Posts 10,999
    • Points 228,425
    Re: ACCESS VIOLATION error while editing in the timeline
    Krossa
    is that all the error message says...?  Can you upload the error exatly as it is...
  • Sun, Jan 26 2020 7:52 PM In reply to
    • krossa
    • Posts 6
    • Points 60
    Hello Marianna. Thank you for responding. The error message stated that an ACCESS VIOLATION exception occured, and referred me to the error log in Avid FatalErrorReports. I have uploaded the initial report.
    There are two other reports that followed in the immediate aftermath and seven others that followed after I shut down and loaded MC a few times over the next day or so. I'd be happy to upload any/all reports that may be of use.
