Latest post Sun, Feb 9 2020 10:15 PM by mtahir. 5 replies.
Page 1 of 1 (6 items)
  • Wed, Feb 5 2020 5:32 PM
    • mtahir
    • UK
    • Posts 503
    • Points 6,120
    Workflow using UHD footage
    Hi Folks,
    I've got some iPhone UHD footage (3840x2160 at 25fps). I have some requirements/choices here:
    1. Create a UHD master.
    2. Create a HD master.
    3. Use FrameFlex to re-frame and create a HD master.
    Can I do all of this through creating a single project or do I require separate projects?
    I was thinking the way to do this is to AMA link, transcode to a proxy format, then re-link once finished?
    Mohammed
    MC2019.12 (Win7) | Dell T7500 with 2 x 6-Core Intel Xeon X5690 3.46GHz CPUs | Triple-Channel 64GB (32GB per CPU) 1333MHz DDR3 EEC FBDIMM | 3GB nVidia Quadro... [view my complete system specs]
    Filed under: , , , ,
  • Wed, Feb 5 2020 5:57 PM In reply to
    • cls105
    • los angeles
    • Posts 486
    • Points 6,245
    Re: Workflow using UHD footage
    always keep the same resolution and frame rate in your transcode settings.
    Then you can change format/resolution within the same project.
  • Sun, Feb 9 2020 5:27 PM In reply to
    • mtahir
    • UK
    • Posts 503
    • Points 6,120
    cls105:
    Thanks for the reply. I'm sorry I don't quite follow.
  • Sun, Feb 9 2020 6:29 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,625
    • Points 43,675
    In your transcode settings you can choose to match project settings or source settings (not the exact wording).  You should choose to match the source settings as this will give you the most options down the road.
    Jef
    Jef Huey
  • Sun, Feb 9 2020 8:27 PM In reply to
    Create a UHD 25p project.
    Transcode your rushes to a UHD resolution like DNxHR HQ (or whatever you choose)
    That's your UHD master.
    Flip the project to 1080p 25 within the Format tab
    Duplicate your sequence
    The UHD footage will automatically have a frameflex effect added which you can manipulate as needed.
    That's your reframed HD master.
    Use the same footage for both, adjust the HD timeline as necessary to reframe.
    I guess if you're not making any adjustments to the shots then you can just export a 1080p file direct from your UHD sequence. Depends on how you're delivering.
    You could do all this without transcoding too, just link to the files and flip the project when needed in the format tab but depending on how much footage you've got you'll notice Avid slowing down pretty fast unless you transcode...
    Andi
    HP ZBook G5 15 2.6Ghz 6-core i7 Nvidia Quadro P2000 4GB 32GB RAM Win 10 Pro MC Ultimate 2018.12.8 MacbookPro 15 2019 6 core 2.6GHz i9 32GB RAM... [view my complete system specs]
  • Sun, Feb 9 2020 10:15 PM In reply to
    • mtahir
    • UK
    • Posts 503
    • Points 6,120
    Thanks guys for the info. Much appreciated. I've just been watching videos from Kevin P McAuliffe and what you're saying is making more sense now.
