Latest post Sun, Feb 9 2020 1:35 PM by WAIF2318. 4 replies.
  • Fri, Feb 7 2020 2:24 AM
    • WAIF2318
    • Joined on Tue, Nov 15 2011
    • Posts 326
    • Points 4,045
    a particle effect for pictures or videos?
    Hi,does AMC have third-party special effects plug-in software that can particleize pictures or videos?
  • Fri, Feb 7 2020 2:13 PM In reply to
    • dew
    • Joined on Tue, Feb 27 2007
    • Posts 566
    • Points 7,245
    Re: a particle effect for pictures or videos?
    Borisfx. Not a lot of tutorials unfortuntely. Not a lot of effects tutorials for avid at all come to think about it.
    https://www.youtube.com/watch?v=ejqwPydTsP0
  • Sun, Feb 9 2020 2:43 AM In reply to
    • WAIF2318
    • Posts 326
    • Points 4,045
    thanks to dear dew.
  • Sun, Feb 9 2020 12:51 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,734
    • Points 61,780
    You could also use BMD Fusion Studio ($300) with its Fusion Connect plugin into Avid for some elaborate particle effects. Here's a link to a YouTube tutorial by VFXStudy: here. This shows the use of Fusion. It does not show the use of Fusion Connect into Avid although you could check out this one here to get a sense of the general workflow.
    It's not quite the same as using BCC (which I highly recommend, although it's expensive) - but the things you can do in Fusion are quite impressive.
    Add - I should mention that the Fusion Connect tutorial uses a very old version of both Fusion and Avid. If you are running Media Composer 2018.7 or later you will require the use of the paid version of Fusion Studio 16.1.1 and the latest Fusion Connect plugin (the plugin is available for download at the BMD support page, Fusion Studio 16.1.1 must be purchased through a 3rd party such as B&H Photo Video - online they are selling the Fusion 9 license (it's a dongle) - this will allow you to run Fusion Studio 16 and also Resolve Studio 16 - so it's a two for one if you buy the Fusion Studio dongle).
    Cheers
    Camera(s) PXW-X70, HDR-FX1, Hero 6 Black | MC 2019.12 | QT 7.7.9 | Continuum 2020 | Sapphire 2020 | Mocha Pro 2020 | Titler Pro 7 | Windows 10 Pro x64... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Sun, Feb 9 2020 1:35 PM In reply to
    • WAIF2318
    • Posts 326
    • Points 4,045
    Thanks to BarkinMadd for your explanation, very good information.
