Latest post Thu, Feb 13 2020 11:30 PM by jef. 5 replies.
Page 1 of 1 (6 items)
  • Tue, Feb 11 2020 11:56 AM
    2018.12.10 still not closing
    Closing 2018.12.10 does not work every time. I had to kill the process many times over the last year, thought it was fixed in2018.12.10?
    i7 3.4 GHz | Asus HERO Z170 | 32GB Ram | Quadro k620 | Intensity Pro 4K | WIN10 Pro [view my complete system specs]
  • Tue, Feb 11 2020 3:07 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 2,575
    • Points 28,485
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Re: 2018.12.10 still not closing
    Thomas,
       I started a case and get support to investigate 03881774.
    RalphC
  • Tue, Feb 11 2020 4:17 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,841
    • Points 46,370
    Thomas Erichsen:
    I am curious.  We are running 2018.12.9 on several Macs.  They often hang on closing but I find if we wait them out they most often do close.  It can be awhile.  Have you tried waiting?
    Jef
    Jef Huey
  • Wed, Feb 12 2020 6:21 AM In reply to
    Hi Jef,
    Sometimes I waited, but in general I don´t see the point. It crashes by itself and has to be restarted for other reasons often enough, for simple things like a new drive is on the system and MC won´t add the drive letter or media tool having a mood, If I waited every time I´d loose too much time. And it´s not doing anything, the used RAM remains constant.
    Thomas
  • Wed, Feb 12 2020 6:22 AM In reply to
    Thanks Ralph.
    RalphC:
  • Thu, Feb 13 2020 11:30 PM In reply to
    • jef
    • Maryland
    • Posts 3,841
    • Points 46,370
    Thomas,
    We have a couple of rooms with this issue and engineering has determined that it is probably related to the use of AJA IO cards in those rooms that are end of life and new drivers are not being written for them (Kona 3G I believe).  Rooms using Black Magic Design IO do not have the issue.
    Don't know if that helps you at all.  I do see that you are using Black Magic Intensity.  I wonder if you were to disable it somehow and test to see if there is interaction causing the issue.
    Jef
    Jef Huey
