Latest post Mon, Mar 30 2020 11:25 PM by apmende. 3 replies.
  • Fri, Mar 27 2020 9:58 PM
    • apmende
    • Posts 38
    • Points 620
    Artifact appears on Render
    Every now and then I get artifacts in my video towards the beginning or ending of an edit.  It sometimes happens after a render.  I have attached a screen shot.  Is this an improper media setting or just an Avid software glitch?
    Thank you!
    Filed under: ,
  • Sat, Mar 28 2020 8:57 AM In reply to
    • Mercer
    • Joined on Thu, Apr 15 2010
    • UK
    • Posts 501
    • Points 6,395
    Re: Artifact appears on Render
    Is this on the Mpeg4 (H264) export and is it always on a fade in/out?
    MC with Symphony option, 2020.4, HP ZBook 17 G5, i7-8850H 6 core/64GB ram/512 M2 ssd/Nvidia Quadro P3200/FHD, HP Thunderbolt Dock G2, BMD Ultrastudio Mini... [view my complete system specs]
  • Sat, Mar 28 2020 9:04 PM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 584
    • Points 6,880
    If it disappears if you clear the render or you do matchframe, then it's a software glitch.
    Disabling gpu acceleration and possibly dual copy engine was a fix for some at some point.
    I had glitches once that looked very different from yours that only cleared with a reinstall.
    Possibly i also had to pull the a fresh OS from a backup image.
    MC 2018.12.2 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-7, Mojo DX, Artist Color, Flanders CM240, GTX... [view my complete system specs]
  • Mon, Mar 30 2020 11:25 PM In reply to
    • apmende
    • Posts 38
    • Points 620
    Thanks, I cleared the renders and that worked.  I initially matched framed back and it wasn't on the source so I knew it had something with how Avid was rendering or playing back the footage.
    thank you!
